Ana içeriğe geç
HP EliteBook 830 G5 Battery Replacement
Neye ihtiyacın var
    • Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
    • Disconnect the power from the computer by unplugging the power cord from the computer
    • Disconnect all external devices from the computer.
  1. HP EliteBook 830 G5 Battery Replacement, Remove the bottom cover: adım 2, 2 resimden 1. HP EliteBook 830 G5 Battery Replacement, Remove the bottom cover: adım 2, 2 resimden 2.
    • Turn the computer upside down on a flat surface.
    • Loosen the five captive screws.
    • Loosen the two inset captive screws.
    • Starting under the display, insert a case removal tool and lift the bottom cover of the computer.
  2. HP EliteBook 830 G5 Battery Replacement, Remove the battery: adım 3, 2 resimden 1. HP EliteBook 830 G5 Battery Replacement, Remove the battery: adım 3, 2 resimden 2.
    • Disconnect the battery cable from the system board.
    • Remove the five Torx T8 2.5×4.0 screws.
    • Rotate the top of the battery upward, and then lift the battery out of the computer.
Sonuç
To replace the battery & reassemble your device, follow these instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
Max Kletskov
40.307 İtibar
16 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
141 Üyeler
17.895 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 26
Son 30 gün: 99
Her zaman: 2,369
