Ana içeriğe geç
HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement, Battery: adım 1, 2 resimden 1. HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement, Battery: adım 1, 2 resimden 2.
    • Use a JIS #0 screwdriver to unscrew the three 6.73 mm case retention screws.
    • Use a JIS #0 screwdriver to unscrew and remove the two 8.76 mm screws.
  2. HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement: adım 2, 2 resimden 1. HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    Halberd Spudger
    $2.99
    • Use the Halberd Spudger to remove the cable running along the bottom of the battery
  3. HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement: adım 3, 2 resimden 1. HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement: adım 3, 2 resimden 2.
    • Disconnect the cable connected the battery to the motherboard
  4. HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement: adım 4, 2 resimden 1. HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement: adım 4, 2 resimden 2.
    • Use a JIS #0 screwdriver to unscrew the four 7 mm screws that secure the battery.
  5. HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement: adım 5, 1 resimden 1.
    • Slide the battery out of the clips to remove it from the laptop.
  6. HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement, Heat Sink and Fan: adım 6, 2 resimden 1. HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement, Heat Sink and Fan: adım 6, 2 resimden 2.
    • Unplug the fan cable from the motherboard.
  7. HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement: adım 7, 2 resimden 1. HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement: adım 7, 2 resimden 2.
    • Use the JIS #0 screwdriver to remove the three 5.33 mm screws that secure the fan.
  8. HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement: adım 8, 2 resimden 1. HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement: adım 8, 2 resimden 2.
    • Use a JIS #0 screwdriver to remove the four 4.06 mm screws from the heat sink.
  9. HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement: adım 9, 1 resimden 1.
    • Lift the fan free.
  10. HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement: adım 10, 1 resimden 1.
    • Lift the heat sink free.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 36
Her zaman: 1,060
