Ana içeriğe geç
HP EliteBook 840 G6 Disassembly
Neye ihtiyacın var
  1. HP EliteBook 840 G6 Disassembly, Identify the screws: adım 1, 1 resimden 1.
    • Identify the screws.
  2. HP EliteBook 840 G6 Disassembly, Unscrew the screws: adım 2, 2 resimden 1. HP EliteBook 840 G6 Disassembly, Unscrew the screws: adım 2, 2 resimden 2.
    • Unscrew the screws.
    • Screws are attached to the back panel.
  3. HP EliteBook 840 G6 Disassembly, Separate back cover from the PC: adım 3, 3 resimden 1. HP EliteBook 840 G6 Disassembly, Separate back cover from the PC: adım 3, 3 resimden 2. HP EliteBook 840 G6 Disassembly, Separate back cover from the PC: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    iFixit Opening Tool
    $1.99
    • Use your fingernail or the iFixit Opening Tool.
    • Start on the far side when prying apart.
    • Open the computer.
    • The display should face the table.
    • Separate gently the back cover from the front panel (keyboard panel).
  4. HP EliteBook 840 G6 Disassembly, Open back and front cover: adım 4, 3 resimden 1. HP EliteBook 840 G6 Disassembly, Open back and front cover: adım 4, 3 resimden 2. HP EliteBook 840 G6 Disassembly, Open back and front cover: adım 4, 3 resimden 3.
    • Open each side gently (keyboard panel is facing up, the back cover is facing down).
    • Store the back cover.
  5. HP EliteBook 840 G6 Disassembly, End result: adım 5, 1 resimden 1.
    • You now have access to the mainboard.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Eric M.
491 İtibar
2 adet Kılavuz yazıldı
2 Yorum
Are the 6 silver-colored screws holding the back cover on all the same length?
David Cary - Yanıt
The central screw has a different size.
Eric M. - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 83
Son 30 gün: 438
Her zaman: 9,219
