Neye ihtiyacın var
Bu adımda kullanılan alet:iFixit Opening Tool$1.99
Use your fingernail or the iFixit Opening Tool.
Start on the far side when prying apart.
Open the computer.
Separate gently the back cover from the front panel (keyboard panel).
Open each side gently (keyboard panel is facing up, the back cover is facing down).
Store the back cover.
You now have access to the mainboard.
Note that the battery is attached using different screws and you need a corresponding screw driver
7 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
Are the 6 silver-colored screws holding the back cover on all the same length?
Pour voir au changer la batterie comment faire ?
Brahim Jelti - Yanıt
