Ana içeriğe geç
HP EliteBook 840 G7 Display Assembly Replacement
Neye ihtiyacın var
  1. HP EliteBook 840 G7 Display Assembly  Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the laptop on its back.
  2. HP EliteBook 840 G7 Display Assembly  Replacement: adım 2, 1 resimden 1.
    • Use the Phillips # 1 screwdriver to remove the five 1.2 mm screws from the back cover of the laptop.
  3. HP EliteBook 840 G7 Display Assembly  Replacement: adım 3, 1 resimden 1.
    • Remove the back cover to expose the hardware.
  4. HP EliteBook 840 G7 Display Assembly  Replacement: adım 4, 3 resimden 1. HP EliteBook 840 G7 Display Assembly  Replacement: adım 4, 3 resimden 2. HP EliteBook 840 G7 Display Assembly  Replacement: adım 4, 3 resimden 3.
    • Use your Phillips #1 screwdriver and remove the four 1.2 mm screws that secures the battery into place.
    • Remove the connector that connects the battery to the motherboard.
  5. HP EliteBook 840 G7 Display Assembly  Replacement: adım 5, 3 resimden 1. HP EliteBook 840 G7 Display Assembly  Replacement: adım 5, 3 resimden 2. HP EliteBook 840 G7 Display Assembly  Replacement: adım 5, 3 resimden 3.
    • Lift up the battery with you hands or tools.
  6. HP EliteBook 840 G7 Display Assembly  Replacement, Display Assembly: adım 6, 2 resimden 1. HP EliteBook 840 G7 Display Assembly  Replacement, Display Assembly: adım 6, 2 resimden 2.
    • Pull up to remove the two coaxial Wi-Fi card connectors.
  7. HP EliteBook 840 G7 Display Assembly  Replacement: adım 7, 2 resimden 1. HP EliteBook 840 G7 Display Assembly  Replacement: adım 7, 2 resimden 2.
    • Pull upwards on the display connector to remove.
  8. HP EliteBook 840 G7 Display Assembly  Replacement: adım 8, 2 resimden 1. HP EliteBook 840 G7 Display Assembly  Replacement: adım 8, 2 resimden 2.
    • Pull or push to remove the bundled cable connector.
  9. HP EliteBook 840 G7 Display Assembly  Replacement: adım 9, 2 resimden 1. HP EliteBook 840 G7 Display Assembly  Replacement: adım 9, 2 resimden 2.
    • Pull upwards to remove the webcam connector.
  10. HP EliteBook 840 G7 Display Assembly  Replacement: adım 10, 1 resimden 1.
    • Once you've disconnected all cables from their sockets, gently move them to the top of the laptop.
  11. HP EliteBook 840 G7 Display Assembly  Replacement: adım 11, 2 resimden 1. HP EliteBook 840 G7 Display Assembly  Replacement: adım 11, 2 resimden 2.
    • Use your Phillips # 1 screwdriver to remove the four 1.2 mm screws.
  12. HP EliteBook 840 G7 Display Assembly  Replacement: adım 12, 2 resimden 1. HP EliteBook 840 G7 Display Assembly  Replacement: adım 12, 2 resimden 2.
    • Use your Phillips # 1 screwdriver to remove the two 1.2mm screws.
  13. HP EliteBook 840 G7 Display Assembly  Replacement: adım 13, 3 resimden 1. HP EliteBook 840 G7 Display Assembly  Replacement: adım 13, 3 resimden 2. HP EliteBook 840 G7 Display Assembly  Replacement: adım 13, 3 resimden 3.
    • Open the laptop to a 90 degree angle.
    • Slide the display hinges away to remove the display assembly.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Pedro Ramos Espinoza
790 İtibar
4 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-1, Pee Spring 2022 Gateway, Team 1-1, Pee Spring 2022 üyesi
GCC-PEE-S22S1G1
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 13
Son 30 gün: 117
Her zaman: 2,672
