Ana içeriğe geç
HP EliteBook 840 G7 Heatsink Replacement
Neye ihtiyacın var
  1. HP EliteBook 840 G7 Heatsink Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the laptop on its back.
  2. HP EliteBook 840 G7 Heatsink Replacement: adım 2, 1 resimden 1.
    • Use the Phillips # 1 screwdriver to remove the five 1.2 mm screws from the back cover of the laptop.
  3. HP EliteBook 840 G7 Heatsink Replacement: adım 3, 1 resimden 1.
    • Remove the back cover to expose the hardware.
  4. HP EliteBook 840 G7 Heatsink Replacement: adım 4, 3 resimden 1. HP EliteBook 840 G7 Heatsink Replacement: adım 4, 3 resimden 2. HP EliteBook 840 G7 Heatsink Replacement: adım 4, 3 resimden 3.
    • Use your Phillips #1 screwdriver and remove the four 1.2 mm screws that secures the battery into place.
    • Remove the connector that connects the battery to the motherboard.
  5. HP EliteBook 840 G7 Heatsink Replacement: adım 5, 3 resimden 1. HP EliteBook 840 G7 Heatsink Replacement: adım 5, 3 resimden 2. HP EliteBook 840 G7 Heatsink Replacement: adım 5, 3 resimden 3.
    • Lift up the battery with you hands or tools.
  6. HP EliteBook 840 G7 Heatsink Replacement, Heatsink: adım 6, 2 resimden 1. HP EliteBook 840 G7 Heatsink Replacement, Heatsink: adım 6, 2 resimden 2.
    • Separate cables from heatsink and fan.
    • Unplug the fan power cable.
  7. HP EliteBook 840 G7 Heatsink Replacement: adım 7, 3 resimden 1. HP EliteBook 840 G7 Heatsink Replacement: adım 7, 3 resimden 2. HP EliteBook 840 G7 Heatsink Replacement: adım 7, 3 resimden 3.
    • Use a Phillips # 1 screwdriver to remove the three 5mm screws from the fan housing.
    • Remove the fan from computer.
  8. HP EliteBook 840 G7 Heatsink Replacement: adım 8, 3 resimden 1. HP EliteBook 840 G7 Heatsink Replacement: adım 8, 3 resimden 2. HP EliteBook 840 G7 Heatsink Replacement: adım 8, 3 resimden 3.
    • Use a Phillips # 1 screwdriver to remove the four 4mm screws from the heatsink.
    • Remove the heat sink from computer.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 36
Her zaman: 617
