Ana içeriğe geç
HP EliteBook 840 G7 Trackpad Replacement
Neye ihtiyacın var
  1. HP EliteBook 840 G7 Trackpad Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the laptop on its back.
  2. HP EliteBook 840 G7 Trackpad Replacement: adım 2, 1 resimden 1.
    • Use the Phillips # 1 screwdriver to remove the five 1.2 mm screws from the back cover of the laptop.
  3. HP EliteBook 840 G7 Trackpad Replacement: adım 3, 1 resimden 1.
    • Remove the back cover to expose the hardware.
  4. HP EliteBook 840 G7 Trackpad Replacement: adım 4, 3 resimden 1. HP EliteBook 840 G7 Trackpad Replacement: adım 4, 3 resimden 2. HP EliteBook 840 G7 Trackpad Replacement: adım 4, 3 resimden 3.
    • Use your Phillips #1 screwdriver and remove the four 1.2 mm screws that secures the battery into place.
    • Remove the connector that connects the battery to the motherboard.
  5. HP EliteBook 840 G7 Trackpad Replacement: adım 5, 3 resimden 1. HP EliteBook 840 G7 Trackpad Replacement: adım 5, 3 resimden 2. HP EliteBook 840 G7 Trackpad Replacement: adım 5, 3 resimden 3.
    • Lift up the battery with you hands or tools.
  6. HP EliteBook 840 G7 Trackpad Replacement, Trackpad: adım 6, 1 resimden 1.
    • Unplug the ribbon cables from the track pad assembly.
  7. HP EliteBook 840 G7 Trackpad Replacement: adım 7, 2 resimden 1. HP EliteBook 840 G7 Trackpad Replacement: adım 7, 2 resimden 2.
    • Use the Philips # 1 screwdriver to remove the four 2.2mm screws securing the track pad assembly.
  8. HP EliteBook 840 G7 Trackpad Replacement: adım 8, 1 resimden 1.
    • Remove the track pad.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 21
Her zaman: 698
