Ana içeriğe geç
HP EliteBook 840 G7 keyboard Replacement
Neye ihtiyacın var
  1. HP EliteBook 840 G7 keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the laptop on its back.
  2. HP EliteBook 840 G7 keyboard Replacement: adım 2, 1 resimden 1.
    • Use the Phillips # 1 screwdriver to remove the five 1.2 mm screws from the back cover of the laptop.
  3. HP EliteBook 840 G7 keyboard Replacement: adım 3, 1 resimden 1.
    • Remove the back cover to expose the hardware.
  4. HP EliteBook 840 G7 keyboard Replacement: adım 4, 3 resimden 1. HP EliteBook 840 G7 keyboard Replacement: adım 4, 3 resimden 2. HP EliteBook 840 G7 keyboard Replacement: adım 4, 3 resimden 3.
    • Use your Phillips #1 screwdriver and remove the four 1.2 mm screws that secures the battery into place.
    • Remove the connector that connects the battery to the motherboard.
  5. HP EliteBook 840 G7 keyboard Replacement: adım 5, 3 resimden 1. HP EliteBook 840 G7 keyboard Replacement: adım 5, 3 resimden 2. HP EliteBook 840 G7 keyboard Replacement: adım 5, 3 resimden 3.
    • Lift up the battery with you hands or tools.
  6. HP EliteBook 840 G7 keyboard Replacement, Display Assembly: adım 6, 2 resimden 1. HP EliteBook 840 G7 keyboard Replacement, Display Assembly: adım 6, 2 resimden 2.
    • Pull up to remove the two coaxial Wi-Fi card connectors.
  7. HP EliteBook 840 G7 keyboard Replacement: adım 7, 2 resimden 1. HP EliteBook 840 G7 keyboard Replacement: adım 7, 2 resimden 2.
    • Pull upwards on the display connector to remove.
  8. HP EliteBook 840 G7 keyboard Replacement: adım 8, 2 resimden 1. HP EliteBook 840 G7 keyboard Replacement: adım 8, 2 resimden 2.
    • Pull or push to remove the bundled cable connector.
  9. HP EliteBook 840 G7 keyboard Replacement: adım 9, 2 resimden 1. HP EliteBook 840 G7 keyboard Replacement: adım 9, 2 resimden 2.
    • Pull upwards to remove the webcam connector.
  10. HP EliteBook 840 G7 keyboard Replacement: adım 10, 1 resimden 1.
    • Once you've disconnected all cables from their sockets, gently move them to the top of the laptop.
  11. HP EliteBook 840 G7 keyboard Replacement: adım 11, 2 resimden 1. HP EliteBook 840 G7 keyboard Replacement: adım 11, 2 resimden 2.
    • Use your Phillips # 1 screwdriver to remove the four 1.2 mm screws.
  12. HP EliteBook 840 G7 keyboard Replacement: adım 12, 2 resimden 1. HP EliteBook 840 G7 keyboard Replacement: adım 12, 2 resimden 2.
    • Use your Phillips # 1 screwdriver to remove the two 1.2mm screws.
  13. HP EliteBook 840 G7 keyboard Replacement: adım 13, 3 resimden 1. HP EliteBook 840 G7 keyboard Replacement: adım 13, 3 resimden 2. HP EliteBook 840 G7 keyboard Replacement: adım 13, 3 resimden 3.
    • Open the laptop to a 90 degree angle.
    • Slide the display hinges away to remove the display assembly.
  14. HP EliteBook 840 G7 keyboard Replacement, Keyboard: adım 14, 3 resimden 1. HP EliteBook 840 G7 keyboard Replacement, Keyboard: adım 14, 3 resimden 2. HP EliteBook 840 G7 keyboard Replacement, Keyboard: adım 14, 3 resimden 3.
    • Pull on the bundled connector to remove.
    • Remove the speaker system from the board.
  15. HP EliteBook 840 G7 keyboard Replacement: adım 15, 2 resimden 1. HP EliteBook 840 G7 keyboard Replacement: adım 15, 2 resimden 2.
    • Push away to remove the bundled connector from its port.
    • Move the cable away from the ZIF connector below.
  16. HP EliteBook 840 G7 keyboard Replacement: adım 16, 3 resimden 1. HP EliteBook 840 G7 keyboard Replacement: adım 16, 3 resimden 2. HP EliteBook 840 G7 keyboard Replacement: adım 16, 3 resimden 3.
    • Lift the latch on the ZIF connector.
    • Pull away on the connector to remove.
  17. HP EliteBook 840 G7 keyboard Replacement: adım 17, 3 resimden 1. HP EliteBook 840 G7 keyboard Replacement: adım 17, 3 resimden 2. HP EliteBook 840 G7 keyboard Replacement: adım 17, 3 resimden 3.
    • Use your Phillips #1 screwdriver to remove the three 1.3 mm screws.
    • Lift up and away to remove the USB ports.
  18. HP EliteBook 840 G7 keyboard Replacement: adım 18, 2 resimden 1. HP EliteBook 840 G7 keyboard Replacement: adım 18, 2 resimden 2.
    • Push away to remove the bundled connector.
  19. HP EliteBook 840 G7 keyboard Replacement: adım 19, 3 resimden 1. HP EliteBook 840 G7 keyboard Replacement: adım 19, 3 resimden 2. HP EliteBook 840 G7 keyboard Replacement: adım 19, 3 resimden 3.
    • Use your Phillips # 1 screwdriver to remove the three 1.2 mm screws that hold the fan in place.
    • Lift up from the left side of the fan then pull towards you to remove.
  20. HP EliteBook 840 G7 keyboard Replacement: adım 20, 3 resimden 1. HP EliteBook 840 G7 keyboard Replacement: adım 20, 3 resimden 2. HP EliteBook 840 G7 keyboard Replacement: adım 20, 3 resimden 3.
    • After removing the connector pull off the CMOS battery.
  21. HP EliteBook 840 G7 keyboard Replacement: adım 21, 3 resimden 1. HP EliteBook 840 G7 keyboard Replacement: adım 21, 3 resimden 2. HP EliteBook 840 G7 keyboard Replacement: adım 21, 3 resimden 3.
    • Use your Phillips #1 screwdriver to remove the single 1.2 mm screw.
    • Pull on the cable to remove the charging port.
  22. HP EliteBook 840 G7 keyboard Replacement: adım 22, 3 resimden 1. HP EliteBook 840 G7 keyboard Replacement: adım 22, 3 resimden 2. HP EliteBook 840 G7 keyboard Replacement: adım 22, 3 resimden 3.
    • Lift on the latch on the ZIF connector.
    • Pull on the cable to remove.
  23. HP EliteBook 840 G7 keyboard Replacement: adım 23, 3 resimden 1. HP EliteBook 840 G7 keyboard Replacement: adım 23, 3 resimden 2. HP EliteBook 840 G7 keyboard Replacement: adım 23, 3 resimden 3.
    • Release the latch on the ZIF connector.
    • Carefully pull the connector to remove.
  24. HP EliteBook 840 G7 keyboard Replacement: adım 24, 3 resimden 1. HP EliteBook 840 G7 keyboard Replacement: adım 24, 3 resimden 2. HP EliteBook 840 G7 keyboard Replacement: adım 24, 3 resimden 3.
    • Use you Phillips #1 screwdriver to remove the eight 1.2 mm screws.
    • Lift the whole board up to remove.
  25. HP EliteBook 840 G7 keyboard Replacement: adım 25, 3 resimden 1. HP EliteBook 840 G7 keyboard Replacement: adım 25, 3 resimden 2. HP EliteBook 840 G7 keyboard Replacement: adım 25, 3 resimden 3.
  26. HP EliteBook 840 G7 keyboard Replacement: adım 26, 3 resimden 1. HP EliteBook 840 G7 keyboard Replacement: adım 26, 3 resimden 2. HP EliteBook 840 G7 keyboard Replacement: adım 26, 3 resimden 3.
  27. HP EliteBook 840 G7 keyboard Replacement: adım 27, 3 resimden 1. HP EliteBook 840 G7 keyboard Replacement: adım 27, 3 resimden 2. HP EliteBook 840 G7 keyboard Replacement: adım 27, 3 resimden 3.
    • Use your Phillips #000 screwdriver to remove the four 1 mm screws.
    • Pull up to remove.
    • Careful to not harm other cables.
  28. HP EliteBook 840 G7 keyboard Replacement: adım 28, 3 resimden 1. HP EliteBook 840 G7 keyboard Replacement: adım 28, 3 resimden 2. HP EliteBook 840 G7 keyboard Replacement: adım 28, 3 resimden 3.
    • Use your Phillips #000 screwdriver to remove the five 1 mm screws.
    • Lift the touchpad to remove.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Pedro Ramos Espinoza
790 İtibar
4 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-1, Pee Spring 2022 Gateway, Team 1-1, Pee Spring 2022 üyesi
GCC-PEE-S22S1G1
4 Üyeler
8 adet Kılavuz yazıldı
3 Yorum
Donc ce tuto permet de tout enlever sauf le clavier?
Pilc - Yanıt
This is only replacement of the touchpad?
Where is the keyboard replacement?
Koehoe22 - Yanıt
the keyboard is part of the top shell and is rivetted in, you need to replace the whole part
Leonardo Di Stefano -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 102
Son 30 gün: 409
Her zaman: 11,521
