Ana içeriğe geç
HP EliteBook 850 G3 Battery Replacement
Neye ihtiyacın var
  1. HP EliteBook 850 G3 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face up.
  2. HP EliteBook 850 G3 Battery Replacement, Unscrew the bottom: adım 2, 2 resimden 1. HP EliteBook 850 G3 Battery Replacement, Unscrew the bottom: adım 2, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove eleven 5.7mm screws.
  3. HP EliteBook 850 G3 Battery Replacement: adım 3, 2 resimden 1. HP EliteBook 850 G3 Battery Replacement: adım 3, 2 resimden 2.
    • Insert the iFixit opening pick underneath the plastic back of the laptop. Use force to pry the back off.
  4. HP EliteBook 850 G3 Battery Replacement, Remove the battery screws: adım 4, 2 resimden 1. HP EliteBook 850 G3 Battery Replacement, Remove the battery screws: adım 4, 2 resimden 2.
    • Use the Phillips #0 screwdriver to remove the two battery screws.
    • The two battery screws are captured screws and do not come out.
  5. HP EliteBook 850 G3 Battery Replacement, Lift the battery: adım 5, 3 resimden 1. HP EliteBook 850 G3 Battery Replacement, Lift the battery: adım 5, 3 resimden 2. HP EliteBook 850 G3 Battery Replacement, Lift the battery: adım 5, 3 resimden 3.
    • Lift and pull the flap located at the top of the battery to remove it.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Annabeth Grover
922 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G1, Leahy Fall 2019 USF Tampa, Team S1-G1, Leahy Fall 2019 üyesi
USFT-LEAHY-F19S1G1
4 Üyeler
6 adet Kılavuz yazıldı
2 Yorum
Thank you very much for this guide.
Geoff Taylor - Yanıt
When charging the charging indicator remain orange for hours and does not change.
Raymond Malken - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 18
Son 30 gün: 105
Her zaman: 9,478
