Ana içeriğe geç
HP EliteBook 850 G3 Motherboard Replacement
Neye ihtiyacın var
  1. HP EliteBook 850 G3 Motherboard Replacement, WiFi Card: adım 1, 1 resimden 1.
    • Turn off your laptop before starting
    • Flip the laptop over so the model stickers face the ceiling.
  2. HP EliteBook 850 G3 Motherboard Replacement: adım 2, 2 resimden 1. HP EliteBook 850 G3 Motherboard Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove eleven 5.7mm screws.
  3. HP EliteBook 850 G3 Motherboard Replacement: adım 3, 2 resimden 1. HP EliteBook 850 G3 Motherboard Replacement: adım 3, 2 resimden 2.
    • Insert the iFixit opening pick underneath the plastic back of the laptop. Use force to pry back off.
  4. HP EliteBook 850 G3 Motherboard Replacement: adım 4, 1 resimden 1.
    • Use the Phillips #0 screwdriver to remove the 3.3mm screw on the WiFi card.
  5. HP EliteBook 850 G3 Motherboard Replacement: adım 5, 2 resimden 1. HP EliteBook 850 G3 Motherboard Replacement: adım 5, 2 resimden 2.
    • Slide out the WiFi card.
  6. HP EliteBook 850 G3 Motherboard Replacement: adım 6, 3 resimden 1. HP EliteBook 850 G3 Motherboard Replacement: adım 6, 3 resimden 2. HP EliteBook 850 G3 Motherboard Replacement: adım 6, 3 resimden 3.
    • Disconnect the coaxial cables wires from the WiFi card.
  7. HP EliteBook 850 G3 Motherboard Replacement, Fan: adım 7, 1 resimden 1.
    • Gently unclip the plastic frame.
  8. HP EliteBook 850 G3 Motherboard Replacement: adım 8, 3 resimden 1. HP EliteBook 850 G3 Motherboard Replacement: adım 8, 3 resimden 2. HP EliteBook 850 G3 Motherboard Replacement: adım 8, 3 resimden 3.
    • Use a Phillips #0 screwdriver to unscrew the four captive screws located near the fan and heatsink assembly.
  9. HP EliteBook 850 G3 Motherboard Replacement: adım 9, 2 resimden 1. HP EliteBook 850 G3 Motherboard Replacement: adım 9, 2 resimden 2.
    • Carefully remove the connector for the fan.
  10. HP EliteBook 850 G3 Motherboard Replacement: adım 10, 3 resimden 1. HP EliteBook 850 G3 Motherboard Replacement: adım 10, 3 resimden 2. HP EliteBook 850 G3 Motherboard Replacement: adım 10, 3 resimden 3.
    • Carefully remove the fan and heatsink assembly from the laptop.
    • Slide out RAM (not pictured).
  11. HP EliteBook 850 G3 Motherboard Replacement: adım 12, 1 resimden 1.
    • Use a #00 Phillips screwdriver to remove twelve 5.7 mm screws from the motherboard.
  12. HP EliteBook 850 G3 Motherboard Replacement: adım 13, 3 resimden 1. HP EliteBook 850 G3 Motherboard Replacement: adım 13, 3 resimden 2. HP EliteBook 850 G3 Motherboard Replacement: adım 13, 3 resimden 3.
    • Remove the wire connectors.
  13. HP EliteBook 850 G3 Motherboard Replacement: adım 14, 2 resimden 1. HP EliteBook 850 G3 Motherboard Replacement: adım 14, 2 resimden 2.
    • Jiggle the motherboard until the ports (ie. headphone jack) come out from the sides and you can lift it up.
  14. HP EliteBook 850 G3 Motherboard Replacement: adım 15, 3 resimden 1. HP EliteBook 850 G3 Motherboard Replacement: adım 15, 3 resimden 2. HP EliteBook 850 G3 Motherboard Replacement: adım 15, 3 resimden 3.
    • Disconnect the wires underneath.
  15. HP EliteBook 850 G3 Motherboard Replacement: adım 16, 3 resimden 1. HP EliteBook 850 G3 Motherboard Replacement: adım 16, 3 resimden 2. HP EliteBook 850 G3 Motherboard Replacement: adım 16, 3 resimden 3.
    • Take out the motherboard.
Sonuç
Annabeth Grover
922 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G1, Leahy Fall 2019 USF Tampa, Team S1-G1, Leahy Fall 2019 üyesi
USFT-LEAHY-F19S1G1
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 14
Son 30 gün: 52
Her zaman: 3,318
