Ana içeriğe geç
HP EliteBook 850 G3 WiFi Card Replacement
Neye ihtiyacın var
  1. HP EliteBook 850 G3 WiFi Card Replacement, WiFi Card: adım 1, 1 resimden 1.
    • Turn off your laptop before starting
    • Flip the laptop over so the model stickers face the ceiling.
  2. HP EliteBook 850 G3 WiFi Card Replacement: adım 2, 2 resimden 1. HP EliteBook 850 G3 WiFi Card Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove eleven 5.7mm screws.
  3. HP EliteBook 850 G3 WiFi Card Replacement: adım 3, 2 resimden 1. HP EliteBook 850 G3 WiFi Card Replacement: adım 3, 2 resimden 2.
    • Insert the iFixit opening pick underneath the plastic back of the laptop. Use force to pry back off.
  4. HP EliteBook 850 G3 WiFi Card Replacement: adım 4, 1 resimden 1.
    • Use the Phillips #0 screwdriver to remove the 3.3mm screw on the WiFi card.
  5. HP EliteBook 850 G3 WiFi Card Replacement: adım 5, 2 resimden 1. HP EliteBook 850 G3 WiFi Card Replacement: adım 5, 2 resimden 2.
    • Slide out the WiFi card.
  6. HP EliteBook 850 G3 WiFi Card Replacement: adım 6, 3 resimden 1. HP EliteBook 850 G3 WiFi Card Replacement: adım 6, 3 resimden 2. HP EliteBook 850 G3 WiFi Card Replacement: adım 6, 3 resimden 3.
    • Disconnect the coaxial cables wires from the WiFi card.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Annabeth Grover
922 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G1, Leahy Fall 2019 USF Tampa, Team S1-G1, Leahy Fall 2019 üyesi
USFT-LEAHY-F19S1G1
4 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
Thank you, my HP Elitebook 850 G3 had a faulty WiFi module, it would only turn on for a second and turn off all the time in Windows 10. Tried everything inc latest drivers and clean W10 install. This guide made it easier than I thought. Replaced WiFi module with a new ordered spare and it works perfectly now.
MV9000 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 25
Her zaman: 1,531
