Ana içeriğe geç
HP EliteBook 8560p Hard Drive Replacement
Neye ihtiyacın var
  1. HP EliteBook 8560p Hard Drive Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Before you begin the repair, make sure the laptop is off, unplugged from the power adapter, and the battery is removed.
    • Flip the laptop over so the bottom is facing up.
  2. HP EliteBook 8560p Hard Drive Replacement: adım 2, 3 resimden 1. HP EliteBook 8560p Hard Drive Replacement: adım 2, 3 resimden 2. HP EliteBook 8560p Hard Drive Replacement: adım 2, 3 resimden 3.
    • Slide and hold the battery lock all the way to the left.
    • While holding the lock open, slide the battery up and out.
    • If the slot for the battery is dirty, cleaning with a microfiber cloth is recommended.
  3. HP EliteBook 8560p Hard Drive Replacement: adım 3, 3 resimden 1. HP EliteBook 8560p Hard Drive Replacement: adım 3, 3 resimden 2. HP EliteBook 8560p Hard Drive Replacement: adım 3, 3 resimden 3.
    • Slide and hold the back cover lock all the way to the right.
    • While holding the lock all the way to the right, slide the back cover down and lift the cover.
  4. HP EliteBook 8560p Hard Drive Replacement: adım 4, 3 resimden 1. HP EliteBook 8560p Hard Drive Replacement: adım 4, 3 resimden 2. HP EliteBook 8560p Hard Drive Replacement: adım 4, 3 resimden 3.
    • Carefully slide the hard drive to the left and lift it out.
  5. HP EliteBook 8560p Hard Drive Replacement: adım 5, 3 resimden 1. HP EliteBook 8560p Hard Drive Replacement: adım 5, 3 resimden 2. HP EliteBook 8560p Hard Drive Replacement: adım 5, 3 resimden 3.
    • Clean the surface and slide in the new hard drive.
  6. HP EliteBook 8560p Hard Drive Replacement: adım 6, 3 resimden 1. HP EliteBook 8560p Hard Drive Replacement: adım 6, 3 resimden 2. HP EliteBook 8560p Hard Drive Replacement: adım 6, 3 resimden 3.
    • Slide the battery back into place.
    • Slide the battery lock to the right to secure the battery.
  7. HP EliteBook 8560p Hard Drive Replacement: adım 7, 3 resimden 1. HP EliteBook 8560p Hard Drive Replacement: adım 7, 3 resimden 2. HP EliteBook 8560p Hard Drive Replacement: adım 7, 3 resimden 3.
    • Replace the back cover.
    • While pushing the back cover upwards, slide the back cover lock to the left.
    • Be sure that both locks are properly closed. The red markers should not be seen.
Sonuç
Make sure to keep your available data space at an optimal level to ensure that your device runs at a normal pace.
Isaiah Villalobos
145 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 38
Her zaman: 69
