Ana içeriğe geç
HP EliteBook 8560w Back Panel Replacement
Neye ihtiyacın var
  1. HP EliteBook 8560w Back Panel Replacement, Battery: adım 1, 2 resimden 1. HP EliteBook 8560w Back Panel Replacement, Battery: adım 1, 2 resimden 2.
    • Make sure your device is powered off and disconnected from the power adapter.
    • Slide the lock all the way to the left. The battery should pop up.
  2. HP EliteBook 8560w Back Panel Replacement: adım 2, 1 resimden 1.
    • Pull the battery out.
  3. HP EliteBook 8560w Back Panel Replacement, Back Panel: adım 3, 2 resimden 1. HP EliteBook 8560w Back Panel Replacement, Back Panel: adım 3, 2 resimden 2.
    • Slide the lock all the way to the right and remove the M2.5x8mm screw with a Philips #0 screwdriver.
    • Make sure your device is turned off and your battery is removed.
  4. HP EliteBook 8560w Back Panel Replacement: adım 4, 1 resimden 1.
    • Slide the panel towards you and lift it up to open and access the back of the computer.
Bitiş Çizgisi
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 33
Her zaman: 1,647
