Giriş
This guide is to show how to replace the keyboard for the HP EliteBook x360 1030 G3. A broken keyboard makes the computer essentially useless and replacing it can allow you to extend the life of your computer.
Neye ihtiyacın var
Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
Remove the remaining four 7.3 mm screws using the same screwdriver.
Remove the five 3.7 mm screws that are holding the battery in place using a Phillips #00 screwdriver.
Use a Phillips #1 screwdriver to remove the four 3.5 mm screws near the middle of the fan assembly.
Use the same screwdriver to remove the remaining five 3.9 mm screws.
Detach the small wires connected to the card by lifting the ends straight upward. The wires are held in place by friction and should pop right off.
Remove the single 5 mm screw holding the HDMI port cover in place using a Phillips #0 screwdriver.
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
Sehr gute Anleitung.
Allerdings sind die 15 Minuten nicht realistisch.
Alleine die Demontage der 57 Schrauben dauert länger.
Zerlegen und wieder zusammenbauen dauert zwischen ein und zwei Stunden.
