Ana içeriğe geç
HP EliteBook x360 1030 G3 Solid State Drive Replacement
Neye ihtiyacın var
  1. HP EliteBook x360 1030 G3 Solid State Drive Replacement, Bottom Cover: adım 1, 1 resimden 1.
    • Be sure to power off and unplug your device before you begin your repair.
    • Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
    • Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
    • Remove the remaining four 7.3 mm screws using the same screwdriver.
  2. HP EliteBook x360 1030 G3 Solid State Drive Replacement: adım 2, 1 resimden 1.
    • Separate the bottom cover from the laptop, starting from the upper corner and working your way around the edge.
    • The plastic fastening may make cracking sounds when separating, but this is normal.
  3. HP EliteBook x360 1030 G3 Solid State Drive Replacement, Solid State Drive: adım 3, 2 resimden 1. HP EliteBook x360 1030 G3 Solid State Drive Replacement, Solid State Drive: adım 3, 2 resimden 2.
    • Lift the black tape covering the solid state drive.
  4. HP EliteBook x360 1030 G3 Solid State Drive Replacement: adım 4, 1 resimden 1.
    • Remove the 2.4 mm screw using a Phillips #00 screwdriver.
  5. HP EliteBook x360 1030 G3 Solid State Drive Replacement: adım 5, 1 resimden 1.
    • Slide the solid state drive to the left and out of its port.
    • Be careful when removing the solid state drive as bending any of the pins may render it unusable.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Pablo Arriola
504 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S2-G9, Maness Spring 2019 Cal Poly, Team S2-G9, Maness Spring 2019 üyesi
CPSU-MANESS-S19S2G9
4 Üyeler
16 adet Kılavuz yazıldı
3 Yorum
Which SSD is compatible with this computer?
Trinayaan Hariharan - Yanıt
Very nice its clear
Fuad Gugsa - Yanıt
J'ai un problème de son
Sallpape - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 30
Son 30 gün: 107
Her zaman: 5,750
