Giriş
This guide explains how to remove the hard drive from the laptop.
Neye ihtiyacın var
Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
Remove the remaining four 7.3 mm screws using the same screwdriver.
3 farklı kişi bu kılavuzu tamamladı.
3 Yorum
Which SSD is compatible with this computer?
Very nice its clear
