Ana içeriğe geç
HP EliteBook x360 1030 G3 Wireless Card Replacement
Neye ihtiyacın var
  1. HP EliteBook x360 1030 G3 Wireless Card Replacement, Bottom Cover: adım 1, 1 resimden 1.
    • Be sure to power off and unplug your device before you begin your repair.
    • Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
    • Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
    • Remove the remaining four 7.3 mm screws using the same screwdriver.
  2. HP EliteBook x360 1030 G3 Wireless Card Replacement: adım 2, 1 resimden 1.
    • Separate the bottom cover from the laptop, starting from the upper corner and working your way around the edge.
    • The plastic fastening may make cracking sounds when separating, but this is normal.
  3. HP EliteBook x360 1030 G3 Wireless Card Replacement, Wireless Card: adım 3, 2 resimden 1. HP EliteBook x360 1030 G3 Wireless Card Replacement, Wireless Card: adım 3, 2 resimden 2.
    • Detach the small wires connected to the card by lifting the ends straight upward. The wires are held in place by friction and should pop right off.
    • These wires should be handled carefully since they're the Wi-Fi and Bluetooth antennas.
    • Take note of which wire goes where, as mixing these cables will cause both Wi-Fi and Bluetooth to stop working.
  4. HP EliteBook x360 1030 G3 Wireless Card Replacement: adım 4, 1 resimden 1.
    • Remove the 2.4 mm screw holding the card down using a Phillips #00 screwdriver.
  5. HP EliteBook x360 1030 G3 Wireless Card Replacement: adım 5, 2 resimden 1. HP EliteBook x360 1030 G3 Wireless Card Replacement: adım 5, 2 resimden 2.
    • Carefully pull out the card by sliding it to the left.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Shea Charkowsky
786 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S2-G9, Maness Spring 2019 Cal Poly, Team S2-G9, Maness Spring 2019 üyesi
CPSU-MANESS-S19S2G9
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 51
Her zaman: 2,311
