Ana içeriğe geç
HP EliteBook x360 830 G5 M2 Solid State Drive Replacement
Neye ihtiyacın var
  1. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement, Back Cover: adım 1, 1 resimden 1.
    • With the T5 screw-bit and screwdriver, loosen the five captive screws on the bottom of the laptop.
  2. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement: adım 2, 2 resimden 1. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement: adım 2, 2 resimden 2.
    • With a spudger or opening tool, pry above the computer's hinges and separate the posterior edge and sides.
  3. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement: adım 3, 1 resimden 1.
    • The back cover is held in place by magnetic strips.
    • Remove the battery.
  4. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement, M.2 Solid State Drive: adım 4, 1 resimden 1.
    • Pull the tab attached to the M.2 solid state drive shield up.
  5. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement: adım 5, 1 resimden 1.
    • With the Phillips #1 screwdriver, loosen the single screw that secures the M.2 solid state drive to the system board.
  6. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement: adım 6, 1 resimden 1.
    • Once the springs release, carefully remove the M.2 solid state drive.
    • Pull the SSD card gently so you don't bend any pins.
Sonuç
Ashia Lewis
246 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 22
Her zaman: 551
