Ana içeriğe geç
HP EliteBook x360 830 G5 Touchpad Replacement
Neye ihtiyacın var
  1. HP EliteBook x360 830 G5 Touchpad Replacement, Back Cover: adım 1, 1 resimden 1.
    • With the T5 screw-bit and screwdriver, loosen the five captive screws on the bottom of the laptop.
  2. HP EliteBook x360 830 G5 Touchpad Replacement: adım 2, 2 resimden 1. HP EliteBook x360 830 G5 Touchpad Replacement: adım 2, 2 resimden 2.
    • With a spudger or opening tool, pry above the computer's hinges and separate the posterior edge and sides.
  3. HP EliteBook x360 830 G5 Touchpad Replacement: adım 3, 1 resimden 1.
    • The back cover is held in place by magnetic strips.
    • Remove the battery.
  4. HP EliteBook x360 830 G5 Touchpad Replacement, Touchpad: adım 4, 1 resimden 1.
    • Use a PH000 screw-bit and a screwdriver and remove the six 2 mm screws securing the touch pad bracket.
    • Remove the touch pad.
Sonuç
Bir Yorum
не подробная инструкция. при снятии на данной модели возникает куча косяков, которые могу привести к порче оборудования
Vladislav Orlov - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 218
