Ana içeriğe geç
HP EliteBook x360 830 G6 CMOS Battery Replacement
Neye ihtiyacın var
  1. HP EliteBook x360 830 G6 CMOS Battery Replacement, Unfasten the back cover: adım 1, 1 resimden 1.
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Torx T5 screwdriver to loosen the five captive screws holding the back cover.
  2. HP EliteBook x360 830 G6 CMOS Battery Replacement, Release the clips: adım 2, 2 resimden 1. HP EliteBook x360 830 G6 CMOS Battery Replacement, Release the clips: adım 2, 2 resimden 2.
    • Insert an opening pick between a corner of the back corner and the chassis, near a hinge.
    • Pry upward to release the retaining clips.
    • These clips will make an audible click when they release.
    • Repeat this process for the opposite corner.
  3. HP EliteBook x360 830 G6 CMOS Battery Replacement, Release the remaining clips: adım 3, 2 resimden 1. HP EliteBook x360 830 G6 CMOS Battery Replacement, Release the remaining clips: adım 3, 2 resimden 2.
    • Insert your opening pick between the back cover and chassis, along the edge of the cover between the hinges.
    • Pry up to release the additional retaining clips.
  4. HP EliteBook x360 830 G6 CMOS Battery Replacement, Remove the back cover: adım 4, 3 resimden 1. HP EliteBook x360 830 G6 CMOS Battery Replacement, Remove the back cover: adım 4, 3 resimden 2. HP EliteBook x360 830 G6 CMOS Battery Replacement, Remove the back cover: adım 4, 3 resimden 3.
    • Grab the cover by the corners next to the hinges.
    • Swing the cover open and away from you.
    • If the back cover feels stuck to the chassis, use an opening pick to release remaining clips around the perimeter of the back cover.
    • Lift and remove the back cover from the laptop body.
  5. HP EliteBook x360 830 G6 CMOS Battery Replacement, Disconnect the battery: adım 5, 3 resimden 1. HP EliteBook x360 830 G6 CMOS Battery Replacement, Disconnect the battery: adım 5, 3 resimden 2. HP EliteBook x360 830 G6 CMOS Battery Replacement, Disconnect the battery: adım 5, 3 resimden 3.
    • Use the point of a spudger to push the sides of the battery connector out of its socket.
    • Push on alternate sides to "walk" the connector out.
  6. HP EliteBook x360 830 G6 CMOS Battery Replacement, CMOS Battery: adım 6, 3 resimden 1. HP EliteBook x360 830 G6 CMOS Battery Replacement, CMOS Battery: adım 6, 3 resimden 2. HP EliteBook x360 830 G6 CMOS Battery Replacement, CMOS Battery: adım 6, 3 resimden 3.
    • Use your fingers or the pointed end of a spudger disconnect the CMOS battery connector.
  7. HP EliteBook x360 830 G6 CMOS Battery Replacement: adım 7, 1 resimden 1.
    • Remove the CMOS battery from its housing by pulling up the small, black plastic tab that is holding it in place.
Sonuç
Brody Reder
301 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 3-3, Harley Spring 2024 IUPUI, Team 3-3, Harley Spring 2024 üyesi
IUPUI-HARLEY-S24S3G3
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 19
Son 30 gün: 25
Her zaman: 54
