Ana içeriğe geç
HP EliteBook x360 830 G7 Display Replacement
Neye ihtiyacın var
  1. HP EliteBook x360 830 G7 Display Replacement, Remove the display: adım 1, 3 resimden 1. HP EliteBook x360 830 G7 Display Replacement, Remove the display: adım 1, 3 resimden 2. HP EliteBook x360 830 G7 Display Replacement, Remove the display: adım 1, 3 resimden 3.
    • Use an opening tool to remove the display from the laptop case. Place it in the area that you see the most give.
    • If you hear the plastic tabs "snapping" free, you should be fine.
    • Be careful not to crack the display.
  2. HP EliteBook x360 830 G7 Display Replacement, Locate the cable connectors: adım 2, 3 resimden 1. HP EliteBook x360 830 G7 Display Replacement, Locate the cable connectors: adım 2, 3 resimden 2. HP EliteBook x360 830 G7 Display Replacement, Locate the cable connectors: adım 2, 3 resimden 3.
    • With the screen removed, locate the pair of wires hidden underneath the two pieces of tape.
  3. HP EliteBook x360 830 G7 Display Replacement, Connector bracket: adım 3, 2 resimden 1. HP EliteBook x360 830 G7 Display Replacement, Connector bracket: adım 3, 2 resimden 2.
    • Use a plastic opening tool or nylon spudger to lift the metal digitizer-connector bracket.
  4. HP EliteBook x360 830 G7 Display Replacement, Disconnect the golden connector: adım 4, 3 resimden 1. HP EliteBook x360 830 G7 Display Replacement, Disconnect the golden connector: adım 4, 3 resimden 2. HP EliteBook x360 830 G7 Display Replacement, Disconnect the golden connector: adım 4, 3 resimden 3.
    • Now that the bracket is removed, pull the golden connector away from the silver base.
    • Now, the back of the display should look like this.
  5. HP EliteBook x360 830 G7 Display Replacement, Peel the black piece of tape: adım 5, 3 resimden 1. HP EliteBook x360 830 G7 Display Replacement, Peel the black piece of tape: adım 5, 3 resimden 2. HP EliteBook x360 830 G7 Display Replacement, Peel the black piece of tape: adım 5, 3 resimden 3.
    • The next piece of tape that needs to be peeled, but not removed, is highlighted by the red rectangle.
    • Peel but do not remove the black piece of tape.
  6. HP EliteBook x360 830 G7 Display Replacement, Peel the clear piece of tape: adım 6, 3 resimden 1. HP EliteBook x360 830 G7 Display Replacement, Peel the clear piece of tape: adım 6, 3 resimden 2. HP EliteBook x360 830 G7 Display Replacement, Peel the clear piece of tape: adım 6, 3 resimden 3.
    • Peel, but do not remove entirely, the clear piece of tape that was underneath the black tape.
  7. HP EliteBook x360 830 G7 Display Replacement, Small ribbon cable connector: adım 7, 3 resimden 1. HP EliteBook x360 830 G7 Display Replacement, Small ribbon cable connector: adım 7, 3 resimden 2. HP EliteBook x360 830 G7 Display Replacement, Small ribbon cable connector: adım 7, 3 resimden 3.
    • Pull the small, bronze "Brighton" ribbon cable connector from the tan connection base.
  8. HP EliteBook x360 830 G7 Display Replacement, Separate the display housing from the computer: adım 8, 1 resimden 1.
    • If you can move your display's housing away from the computer, then you have successfully detached your display and can replace it.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 16
Son 30 gün: 103
Her zaman: 1,881
