Ana içeriğe geç
HP EliteBook x360 830 G7 RAM Replacement
Neye ihtiyacın var
  1. HP EliteBook x360 830 G7 RAM Replacement, Remove the backplate: adım 1, 2 resimden 1. HP EliteBook x360 830 G7 RAM Replacement, Remove the backplate: adım 1, 2 resimden 2.
    • Turn the computer over so the back is facing up.
    • Use a Torx T5 screwdriver to remove the three 9 mm screws from the hinge of the device.
    • Use a Torx T5 screwdriver to remove the two 7 mm screws from the left and right mid-section of the case.
    • Lift the backplate from the computer.
  2. HP EliteBook x360 830 G7 RAM Replacement, Remove the shield: adım 2, 3 resimden 1. HP EliteBook x360 830 G7 RAM Replacement, Remove the shield: adım 2, 3 resimden 2. HP EliteBook x360 830 G7 RAM Replacement, Remove the shield: adım 2, 3 resimden 3.
    • Gently lift the larger, rectangular metal shielding off. This shielding covers the RAM.
  3. HP EliteBook x360 830 G7 RAM Replacement, Remove the RAM: adım 3, 1 resimden 1.
    • Push down on the two latches on both sides of the RAM to release it.
    • This will allow you to remove the RAM and replace it with no issues.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 72
Her zaman: 1,068
