Ana içeriğe geç
HP EliteOne 800 G1 Fan Assembly Replacement
Neye ihtiyacın var
    1. HP EliteOne 800 G1 Fan Assembly Replacement, Removing the Back Cover: adım 1, 3 resimden 1. HP EliteOne 800 G1 Fan Assembly Replacement, Removing the Back Cover: adım 1, 3 resimden 2. HP EliteOne 800 G1 Fan Assembly Replacement, Removing the Back Cover: adım 1, 3 resimden 3.
      • Place computer with the screen down on a flat surface.
      • Push the two locking latches to the unlocked position.
      • Push the cover toward the top of the computer and lift up.
      FixBot'a Sor
      Yorum Ekle
    1. HP EliteOne 800 G1 Fan Assembly Replacement, Removing Stand: adım 2, 2 resimden 1. HP EliteOne 800 G1 Fan Assembly Replacement, Removing Stand: adım 2, 2 resimden 2.
      • Press locking latch on the bottom of the base of the stand.
      • Pull the plastic cover off of the stand.
      FixBot'a Sor
      Yorum Ekle
    2. HP EliteOne 800 G1 Fan Assembly Replacement: adım 3, 2 resimden 1. HP EliteOne 800 G1 Fan Assembly Replacement: adım 3, 2 resimden 2.
      • Use a Torx T15 driver and stick it through the holes on the stand in order to remove the two 12mm screws on the back of the main unit.
      • Tilt stand and lift up to remove it.
      FixBot'a Sor
      Yorum Ekle
    3. HP EliteOne 800 G1 Fan Assembly Replacement: adım 4, 2 resimden 1. HP EliteOne 800 G1 Fan Assembly Replacement: adım 4, 2 resimden 2.
      • Use a Torx T15 driver to remove the single 10mm screw on the back panel.
      • Pull the back panel toward the bottom of the device to remove it.
      FixBot'a Sor
      Yorum Ekle
    1. HP EliteOne 800 G1 Fan Assembly Replacement, Fan Assembly: adım 5, 1 resimden 1.
      • Disconnect these two power connectors on the motherboard, one connector is white and the other is black. You can identify the correct wires by their braided colors: red, yellow, blue, and black.
      FixBot'a Sor
      Yorum Ekle
    2. HP EliteOne 800 G1 Fan Assembly Replacement: adım 6, 2 resimden 1. HP EliteOne 800 G1 Fan Assembly Replacement: adım 6, 2 resimden 2.
      • Use a Torx T15 driver to remove the three 6mm screws surrounding the fan assembly.
      • Pull the fan assembly up from the case to remove it.
      FixBot'a Sor
      Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Michael Ewing
1.071 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-24, Maness Fall 2015 Cal Poly, Team 1-24, Maness Fall 2015 üyesi
CPSU-MANESS-F15S1G24
4 Üyeler
28 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 34
Her zaman: 7,466
