Ana içeriğe geç
HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement
Neye ihtiyacın var
  1. HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement, Hard Disk Drive / Solid State Drive: adım 1, 3 resimden 1. HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement, Hard Disk Drive / Solid State Drive: adım 1, 3 resimden 2. HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement, Hard Disk Drive / Solid State Drive: adım 1, 3 resimden 3.
    • Place the computer screen down on a flat surface.
    • Push the two locking latches to the unlocked position.
    • Push the cover toward the top of the computer and lift up.
  2. HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: adım 2, 3 resimden 1. HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: adım 2, 3 resimden 2. HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: adım 2, 3 resimden 3.
    • Grasp the handle on the hard drive cage to the left of the stand. It is marked with green.
    • Pull the handle up, allowing the entire cage to slide toward the outward edge of the computer.
    • Pull the entire cage up and out of the device.
  3. HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: adım 3, 2 resimden 1. HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: adım 3, 2 resimden 2.
    • Once the cage is out of the device, use a Torx T15 driver to unscrew the four 10mm screws keeping the drive in place. There are two screws on each side.
    • Once all the screws are removed, lift the drive out of the cage.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Kyle Koivuniemi
605 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-24, Maness Fall 2015 Cal Poly, Team 1-24, Maness Fall 2015 üyesi
CPSU-MANESS-F15S1G24
4 Üyeler
14 adet Kılavuz yazıldı
2 Yorum
where can i buy a replace cage for the hard drive?
Thomas Dickson - Yanıt
What replacement guide can I buy for my HP EliteOne 800 G1 all in one?
Hank Trujillo - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 26
Son 30 gün: 63
Her zaman: 8,962
