Ana içeriğe geç
HP EliteOne 800 G1 Power Supply Replacement
Neye ihtiyacın var
  1. HP EliteOne 800 G1 Power Supply Replacement, Removing the Back Cover: adım 1, 3 resimden 1. HP EliteOne 800 G1 Power Supply Replacement, Removing the Back Cover: adım 1, 3 resimden 2. HP EliteOne 800 G1 Power Supply Replacement, Removing the Back Cover: adım 1, 3 resimden 3.
    • Place computer with the screen down on a flat surface.
    • Push the two locking latches to the unlocked position.
    • Push the cover toward the top of the computer and lift up.
  2. HP EliteOne 800 G1 Power Supply Replacement, Removing Stand: adım 2, 2 resimden 1. HP EliteOne 800 G1 Power Supply Replacement, Removing Stand: adım 2, 2 resimden 2.
    • Press locking latch on the bottom of the base of the stand.
    • Pull the plastic cover off of the stand.
  3. HP EliteOne 800 G1 Power Supply Replacement: adım 3, 2 resimden 1. HP EliteOne 800 G1 Power Supply Replacement: adım 3, 2 resimden 2.
    • Use a Torx T15 driver and stick it through the holes on the stand in order to remove the two 12mm screws on the back of the main unit.
    • Tilt stand and lift up to remove it.
  4. HP EliteOne 800 G1 Power Supply Replacement: adım 4, 2 resimden 1. HP EliteOne 800 G1 Power Supply Replacement: adım 4, 2 resimden 2.
    • Use a Torx T15 driver to remove the single 10mm screw on the back panel.
    • Pull the back panel toward the bottom of the device to remove it.
  5. HP EliteOne 800 G1 Power Supply Replacement, Power Supply: adım 5, 2 resimden 1. HP EliteOne 800 G1 Power Supply Replacement, Power Supply: adım 5, 2 resimden 2.
    • Use a Torx T15 driver to remove the four 10mm screws on the VESA mount cover.
    • Lift up on the VESA mount cover to remove it.
  6. HP EliteOne 800 G1 Power Supply Replacement: adım 6, 1 resimden 1.
    • Disconnect the power supply's black and yellow cable from the motherboard.
  7. HP EliteOne 800 G1 Power Supply Replacement: adım 7, 2 resimden 1. HP EliteOne 800 G1 Power Supply Replacement: adım 7, 2 resimden 2.
    • Use a Torx T15 driver to remove the two 8mm screws on either side of the power supply.
    • Lift the power supply from the case to remove it.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Michael Ewing
1.071 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-24, Maness Fall 2015 Cal Poly, Team 1-24, Maness Fall 2015 üyesi
CPSU-MANESS-F15S1G24
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 52
Her zaman: 5,304
