Giriş
Use this guide to replace the battery in your HP ElitePad 900.
Neye ihtiyacın var
Unscrew the two 2.8mm Phillips #000 screws near the power connector.
Remove the six 2.2mm Phillips #000 screws securing the battery to the device.
13 farklı kişi bu kılavuzu tamamladı.
2 Yorum
One way to remove screen assembly without a suction cup is to use a piece of duct tape folded onto to itself leaving a small amount of the adhesive portion exposed. This creates a little handle. You can then stick it to assembly and lift it out easily.
