Ana içeriğe geç
HP ElitePad 900 Volume Control Buttons Replacement
Neye ihtiyacın var
  1. HP ElitePad 900 Volume Control Buttons Replacement, Front Panel Assembly: adım 1, 1 resimden 1.
    • Unscrew the two 2.8mm Phillips #000 screws near the power connector.
  2. HP ElitePad 900 Volume Control Buttons Replacement: adım 2, 2 resimden 1. HP ElitePad 900 Volume Control Buttons Replacement: adım 2, 2 resimden 2.
    • Use a suction cup to pull the display assembly up.
  3. HP ElitePad 900 Volume Control Buttons Replacement: adım 3, 2 resimden 1. HP ElitePad 900 Volume Control Buttons Replacement: adım 3, 2 resimden 2.
    • Use the tip of a spudger to disconnect the two display ZIF connectors.
  4. HP ElitePad 900 Volume Control Buttons Replacement, Volume Control Buttons: adım 4, 3 resimden 1. HP ElitePad 900 Volume Control Buttons Replacement, Volume Control Buttons: adım 4, 3 resimden 2. HP ElitePad 900 Volume Control Buttons Replacement, Volume Control Buttons: adım 4, 3 resimden 3.
    • Using the Phillips screwdriver remove the two 2.4mm #000 screws that are securing the volume control buttons to the device.
    • Lift up the silver panel, removing it completely from the device
    • Push the buttons through the slot to remove them from the device
Sonuç
Kyle Marques
889 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 12-4, Blackwell Fall 2015 USF Tampa, Team 12-4, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S12G4
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 655
