Ana içeriğe geç
HP Elitebook 2740p Hard Drive Replacement
Neye ihtiyacın var
  1. HP Elitebook 2740p Hard Drive Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Place the laptop face down in front of you.
    • Use a Phillips #0 screwdriver to remove the three 3 mm screws from the back of the case.
    • Remove the back panel.
  2. HP Elitebook 2740p Hard Drive Replacement: adım 2, 3 resimden 1. HP Elitebook 2740p Hard Drive Replacement: adım 2, 3 resimden 2. HP Elitebook 2740p Hard Drive Replacement: adım 2, 3 resimden 3.
    • Use a Phillips #0 screwdriver to remove the two 3 mm screws from the small metal HDD bracket.
    • Lift up on the small bracket and pull it off.
  3. HP Elitebook 2740p Hard Drive Replacement: adım 3, 3 resimden 1. HP Elitebook 2740p Hard Drive Replacement: adım 3, 3 resimden 2. HP Elitebook 2740p Hard Drive Replacement: adım 3, 3 resimden 3.
    • Pull out the hard drive and the small rubber sleigh that holds it.
    • Pull the rubber sleigh off of the hard drive.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Cameron Whittle
467 İtibar
2 adet Kılavuz yazıldı
Ekip
Bir Yorum
You can use any mSATA SSD as replacement by using the following caddy/adapter:
https://www.ebay.fr/itm/165266235415
jacques_06
jacques_06 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 16
Son 30 gün: 62
Her zaman: 5,924
