Ana içeriğe geç
HP Elitebook 2740p Screen Replacement
Neye ihtiyacın var
  1. HP Elitebook 2740p Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Slide the lock tab to the right.
  2. HP Elitebook 2740p Screen Replacement: adım 2, 1 resimden 1.
    • Lift and remove the battery from the battery compartment.
  3. HP Elitebook 2740p Screen Replacement, Screen: adım 3, 3 resimden 1. HP Elitebook 2740p Screen Replacement, Screen: adım 3, 3 resimden 2. HP Elitebook 2740p Screen Replacement, Screen: adım 3, 3 resimden 3.
    • Locate the radio antenna on the right side of the top edge of the screen. Slide the latch to release the antenna.
    • Use a Phillips #0 screwdriver to remove the two 4 mm screws recessed in the antenna housing.
  4. HP Elitebook 2740p Screen Replacement: adım 4, 3 resimden 1. HP Elitebook 2740p Screen Replacement: adım 4, 3 resimden 2. HP Elitebook 2740p Screen Replacement: adım 4, 3 resimden 3.
    • Use a metal spudger to separate bezel from laptop body. there are tabs holding the bezel on along the entire bezel.
    • Pay special attention to the hinge cover at the bottom. It has tabs at both the top and bottom.
    • Remove the bezel from the laptop.
  5. HP Elitebook 2740p Screen Replacement: adım 5, 3 resimden 1. HP Elitebook 2740p Screen Replacement: adım 5, 3 resimden 2. HP Elitebook 2740p Screen Replacement: adım 5, 3 resimden 3.
    • Use a Phillips #0 screwdriver to remove the eight 4 mm screws that hold the frame of the screen in place.
    • Use a Phillips #00 screwdriver to remove the single 3 mm screw at the corner of the frame.
  6. HP Elitebook 2740p Screen Replacement: adım 6, 3 resimden 1. HP Elitebook 2740p Screen Replacement: adım 6, 3 resimden 2. HP Elitebook 2740p Screen Replacement: adım 6, 3 resimden 3.
    • Use a Phillips #0 screwdriver to remove the two 4 mm screws that hold the tilt button in place.
    • Remove the tilt button.
  7. HP Elitebook 2740p Screen Replacement: adım 7, 3 resimden 1. HP Elitebook 2740p Screen Replacement: adım 7, 3 resimden 2. HP Elitebook 2740p Screen Replacement: adım 7, 3 resimden 3.
    • Use a Phillips #0 screwdriver to remove the three screws that secure the tablet-mode button board.
    • Disconnect the two blue ribbon cables and gently pull them free.
    • Remove the PCB board from the screen housing.
  8. HP Elitebook 2740p Screen Replacement: adım 8, 3 resimden 1. HP Elitebook 2740p Screen Replacement: adım 8, 3 resimden 2. HP Elitebook 2740p Screen Replacement: adım 8, 3 resimden 3.
    • Remove the gray rubber pad at the top of the screen next to the camera.
    • Remove the 3mm screw with a Phillips #0 screwdriver
    • Carefully tilt the screen down onto the keayboard
  9. HP Elitebook 2740p Screen Replacement: adım 9, 2 resimden 1. HP Elitebook 2740p Screen Replacement: adım 9, 2 resimden 2.
    • Fold the protective foil back from the ribbon cables.
  10. HP Elitebook 2740p Screen Replacement: adım 10, 3 resimden 1. HP Elitebook 2740p Screen Replacement: adım 10, 3 resimden 2. HP Elitebook 2740p Screen Replacement: adım 10, 3 resimden 3.
    • Unseat display ribbon cables.
    • Ribbon cables are secured with tape. Do not force the cables out of their sockets.
    • Remove the screen.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Joseph Hazel
353 İtibar
2 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 1,392
