Ana içeriğe geç
HP Elitebook 6930p RAM (Expansion Slot) Replacement
Neye ihtiyacın var
  1. HP Elitebook 6930p RAM (Expansion Slot) Replacement, Battery Removal: adım 1, 3 resimden 1. HP Elitebook 6930p RAM (Expansion Slot) Replacement, Battery Removal: adım 1, 3 resimden 2. HP Elitebook 6930p RAM (Expansion Slot) Replacement, Battery Removal: adım 1, 3 resimden 3.
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. HP Elitebook 6930p RAM (Expansion Slot) Replacement, RAM (Expansion Slot): adım 2, 2 resimden 1. HP Elitebook 6930p RAM (Expansion Slot) Replacement, RAM (Expansion Slot): adım 2, 2 resimden 2.
    • Locate the RAM expansion slot cover on the bottom of the laptop
    • Loosen the PM2.0×5.0 captive screw and remove the cover.
  3. HP Elitebook 6930p RAM (Expansion Slot) Replacement: adım 3, 2 resimden 1. HP Elitebook 6930p RAM (Expansion Slot) Replacement: adım 3, 2 resimden 2.
    • Install RAM module into the RAM slot on an angle of around 30 degrees
    • Press the RAM module down with your fingers on each corner until it clicks into the 2 metal clips and is locked down
    • Check to ensure the metal tabs are holding the RAM module down on both sides
    • Reinstall the RAM cover
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Richdave
32.401 İtibar
30 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
326 Üyeler
1.672 adet Kılavuz yazıldı
17Kılavuz Yorumları
What kind of RAM do you place in this slot?
I want to upgrade my notebook, maybe with some RAM from ebay, so, What should I buy?
Jan Cerenohorsky - Yanıt
Also, is there already any RAM by default? What is the maximum capacity you can upgrade to?
Jan Cerenohorsky -
Yes under the Keyboard and the Max is 8GB DDR2 6400
dcliddle - Yanıt
Can you add an 8GB DDR2 6400 to your laptop (HP6930p) without upgrading or changing the factory installed one? The label on the bottom of mine says C2D P8700 2.53 GHz 4GB.
Thanks for any help!
Brian Fenech - Yanıt
Thank you for information.
By p8slot.com
sutep Fifa - Yanıt
Thanks for such amazing stuff. Please keep sharing.
<a href="https://168slotxo.net/the-secert-slot-on...>ความลับของสล็อตออนไลน์ในคาสิโน</a>
Shoaib - Yanıt
Thanks for such an amazing stuff. Please keep sharing.
<a href="https://168slotxo.net/168slotxo-the-best...>สล็อตออนไลน์</a>
Shoaib - Yanıt
You always share so amazing articles. I really love it.
slotxo
Shoaib - Yanıt
You always share so amazing articles. I love it.
slotxo
Shoaib - Yanıt
I am a big fan of your site and content.
pg
Shoaib - Yanıt
I am a big fan of your site and amazing content.
pgslot
Shoaib - Yanıt
Your content is always awesome.
pg
Shoaib - Yanıt
Your site is awesome. I will recommend this to everyone.
pg slot
Shoaib - Yanıt
Amazing woRK..
joker
Shoaib - Yanıt
Thanks for this information, please can i add 8gb to my expansion slot and leave the other 2gb that is under the keyboard?
Emeba Okeoghene - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 30
Her zaman: 15,823
