Ana içeriğe geç
HP Elitebook 820 G1 Battery Replacement
Neye ihtiyacın var
  1. HP Elitebook 820 G1 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Ensure the laptop is completely powered off and power adapter is unplugged before removing the battery.
    • Turn over laptop so that the bottom is showing.
    • Unlock the latch.
  2. HP Elitebook 820 G1 Battery Replacement: adım 2, 1 resimden 1.
    • Remove the back cover and you will then be able to see the battery.
  3. HP Elitebook 820 G1 Battery Replacement: adım 3, 1 resimden 1.
    • Unlatch the two latches securing the battery in the case.
  4. HP Elitebook 820 G1 Battery Replacement: adım 4, 1 resimden 1.
    • Use a plastic opening tool to lift and remove the battery.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ekip
USF Tampa, Team S5-G1, Eyestone Spring 2018 USF Tampa, Team S5-G1, Eyestone Spring 2018 üyesi
USFT-EYESTONE-S18S5G1
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 43
Her zaman: 11,367
