Ana içeriğe geç
HP Elitebook 820 G1 Keyboard Replacement
Neye ihtiyacın var
  1. HP Elitebook 820 G1 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Ensure the laptop is completely powered off and power adapter is unplugged before removing the battery.
    • Turn over laptop so that the bottom is showing.
    • Unlock the latch.
  2. HP Elitebook 820 G1 Keyboard Replacement: adım 2, 1 resimden 1.
    • Remove the back cover and you will then be able to see the battery.
  3. HP Elitebook 820 G1 Keyboard Replacement: adım 3, 1 resimden 1.
    • Unlatch the two latches securing the battery in the case.
  4. HP Elitebook 820 G1 Keyboard Replacement: adım 4, 1 resimden 1.
    • Use a plastic opening tool to lift and remove the battery.
  5. HP Elitebook 820 G1 Keyboard Replacement, Keyboard: adım 5, 1 resimden 1.
    • Remove the two Phillips #0 screws securing the keyboard to the laptop.
    • Turn the laptop over and lift the display to reveal the keyboard.
  6. HP Elitebook 820 G1 Keyboard Replacement: adım 6, 1 resimden 1.
    • Insert the plastic spudger between the keyboard and the housing.
    • Start at the corner.
  7. HP Elitebook 820 G1 Keyboard Replacement: adım 7, 3 resimden 1. HP Elitebook 820 G1 Keyboard Replacement: adım 7, 3 resimden 2. HP Elitebook 820 G1 Keyboard Replacement: adım 7, 3 resimden 3.
    • 4 tabs are located at the top of the keyboard, which lock it in place.
    • Pry and twist the spudger along the top of the keyboard until each tab is released.
  8. HP Elitebook 820 G1 Keyboard Replacement: adım 8, 1 resimden 1.
    • Pull back the keyboard from the top.
    • Be mindful of the fragile cables behind it.
  9. HP Elitebook 820 G1 Keyboard Replacement: adım 9, 3 resimden 1. HP Elitebook 820 G1 Keyboard Replacement: adım 9, 3 resimden 2. HP Elitebook 820 G1 Keyboard Replacement: adım 9, 3 resimden 3.
    • Flip up the connecting flap on each of the three ribbon cables.
    • The small cable on the last picture ist only there, if you have a backlit keyboard. If you want to replace a keyboard without backlight, there will be no cable on your original keyboard.
  10. HP Elitebook 820 G1 Keyboard Replacement: adım 10, 3 resimden 1. HP Elitebook 820 G1 Keyboard Replacement: adım 10, 3 resimden 2. HP Elitebook 820 G1 Keyboard Replacement: adım 10, 3 resimden 3.
    • Remove each of the three cables by gently pulling them from their respective connectors.
  11. HP Elitebook 820 G1 Keyboard Replacement: adım 11, 1 resimden 1.
    • Remove the keyboard from the housing.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Lauren Vance
388 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G2, Harley Fall 2018 IUPUI, Team S1-G2, Harley Fall 2018 üyesi
IUPUI-HARLEY-F18S1G2
2 Üyeler
4 adet Kılavuz yazıldı
Bir Yorum
Good guide. Thanks!
But you missed step 1. Remove two screws that hold the keyboard in place
Chris Maschmeier - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 38
Her zaman: 11,031
