Ana içeriğe geç
Giriş
RAM should be replaced when the device returns several beeps and fails to power on.
Parçalar
Hiçbir parça belirtilmedi.
  1. Ensure the laptop is completely powered off and power adapter is unplugged before removing the battery.
    • Ensure the laptop is completely powered off and power adapter is unplugged before removing the battery.
    • Turn over laptop so that the bottom is showing.
    • Unlock the latch.
  2. Remove the back cover and you will then be able to see the battery.
    • Remove the back cover and you will then be able to see the battery.
  3. MacBook Pil Tamir Setleri
    Başlangıç $69.99
    Buy Now
    Başlangıç $69.99
    Buy Now
  4. Unlatch the two latches securing the battery in the case.
    • Unlatch the two latches securing the battery in the case.
  5. Use the blue opening tool to lift and remove the battery.
    • Use the blue opening tool to lift and remove the battery.
  6. Once the battery is removed from the device, slide both latches away from the RAM module with your fingers.
    • Once the battery is removed from the device, slide both latches away from the RAM module with your fingers.
    • The latches are spring assisted and the RAM module will lift for removal.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Ashley Francavilla
103 İtibar
1 Kılavuz yazıldı
Takım
USF Tampa, Team S5-G1, Eyestone Spring 2018 USF Tampa, Team S5-G1, Eyestone Spring 2018 üyesi
USFT-EYESTONE-S18S5G1
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 3
Son 30 Gün: 19
Her zaman: 256
