Giriş
RAM should be replaced when the device returns several beeps and fails to power on.
Neye ihtiyacın var
Once the battery is removed from the device, slide both latches away from the RAM module with your fingers.
The latches are spring assisted and the RAM module will lift for removal.
2 farklı kişi bu kılavuzu tamamladı.
