Ana içeriğe geç
HP Elitebook 840 G1 Hard Drive Replacement
Neye ihtiyacın var
  1. HP Elitebook 840 G1 Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Slide the latch, to the right, away from the lock symbol.
    • Slide the cover away from the latch to remove it.
    Slide to your "other left", on this screen it would be to the right, to slide open the cover
    petunia8107 - Yanıt
    l’expression “Détachez le cache du loquet pour le retirer “ est ambigüe et source d’erreur, elle donne à penser qu’il faut retirer un “cache” qui serait sur le loquet.
    Ce qu’il faut c’est détacher le cache (la grande plaque où il y a la logo bleu) de la partie fixe sur laquelle se trouve le loquet. Pour ça il faut glisser une lame fine dans la fente entre le cache et la partie fixe.
    merci pour le tutoriel.
    Philippe Fayolle - Yanıt
    Bonjour Philippe,
    Vous avez bien raison ! J’ai adapté la traduction. Merci pour l’observation ! N’hésitez pas à corriger le texte la prochaine fois. Vous trouverez l’interface de traduction en cliquant sur Traduire en haut à droite de l’étape.
    Bonne réparation !
    Claire Miesch -
  2. HP Elitebook 840 G1 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Once the cover is removed you will be able to see the battery and the two latches that hold it in place.
    • The two latches should be pulled back, one of which is spring loaded and must be held in place in order to remove the battery.
  3. HP Elitebook 840 G1 Hard Drive Replacement: adım 3, 1 resimden 1.
    • Battery should easily be lifted up and out.
  4. HP Elitebook 840 G1 Hard Drive Replacement, Hard Drive: adım 4, 2 resimden 1. HP Elitebook 840 G1 Hard Drive Replacement, Hard Drive: adım 4, 2 resimden 2.
    • Loosen the four Phillips screws securing the hard drive.
    • These screws will stay captive to the plastic hard drive bracket.
    These are J1 Phillips screws
    Bradley Pinkston - Yanıt
  5. HP Elitebook 840 G1 Hard Drive Replacement: adım 5, 1 resimden 1.
    • Grab the pull tab on the hard drives plastic casing and pull it out and to the side.
    • Make sure all screws have been properly loosened and are no longer connected at the bottom before doing this step.
    • Remove the 2.5" hard drive from the plastic bracket.
    Festplatte ist leer wie bekomm ich Windows drauf
    Böhser Ossi - Yanıt
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Ashley Williams
2.419 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 5-3, Blackwell Fall 2015 USF Tampa, Team 5-3, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S5G3
4 Üyeler
19 adet Kılavuz yazıldı
3Kılavuz Yorumları
I'm surprised not to see a caution about removing the hard drive, but I guess generally I fixit users are pretty computer savvy!
cadegans - Yanıt
The NEW hard drive does NOT have any OP system.  How does that work now ?????
Frank Mraz - Yanıt
In case you're still looking for an answer:
-Create a bootable usb flash drive with your os of choice: Download rufus, get iso file of os, flash the iso to the usb drive via rufus. (Unfortunately need a pc for this part).
-Put usb drive to your notebook and turn it on.
-Most notebooks should automatically start from that usb drive. However if not: your notebook brand should have specific button for that (Eg.: ESC, F2). You can google that and find out… OR choose usb drive as first boot option in your BIOS.
PS: If windows asks for key on installation, skip that part and use Microsoft Toolkit to activate it later ;)
Eren Üstün -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 19
Son 30 gün: 149
Her zaman: 28,731
