Ana içeriğe geç
HP Elitebook 8460p Keyboard Replacement
Neye ihtiyacın var
  1. HP Elitebook 8460p Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
    what if it does not work,what does that mean?
    julia melrose - Yanıt
  2. HP Elitebook 8460p Keyboard Replacement: adım 2, 1 resimden 1.
    • Slide the battery away from the switches until it can be lifted away from the laptop.
    • Lift the battery away from the laptop.
  3. HP Elitebook 8460p Keyboard Replacement, Back Panel: adım 3, 1 resimden 1.
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  4. HP Elitebook 8460p Keyboard Replacement: adım 4, 1 resimden 1.
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
  5. HP Elitebook 8460p Keyboard Replacement, Keyboard: adım 5, 3 resimden 1. HP Elitebook 8460p Keyboard Replacement, Keyboard: adım 5, 3 resimden 2. HP Elitebook 8460p Keyboard Replacement, Keyboard: adım 5, 3 resimden 3.
    • Attach ESD strap around your wrist and to a ground.
    • Using a Phillips #0 bit, unscrew the two screws in front of the battery slot located on the bottom of the laptop.
    There is a 3rd screw by the CPU fan.
    Winfried Lange - Yanıt
  6. HP Elitebook 8460p Keyboard Replacement: adım 6, 1 resimden 1.
    • Flip the laptop over and open the screen.
  7. HP Elitebook 8460p Keyboard Replacement: adım 7, 3 resimden 1. HP Elitebook 8460p Keyboard Replacement: adım 7, 3 resimden 2. HP Elitebook 8460p Keyboard Replacement: adım 7, 3 resimden 3.
    • Using a spudger, work around the edge of the keyboard and pry it up from the device.
  8. HP Elitebook 8460p Keyboard Replacement: adım 8, 2 resimden 1. HP Elitebook 8460p Keyboard Replacement: adım 8, 2 resimden 2.
    • Lift the keyboard out of the laptop and flip it over.
    • This exposes two different connectors. Both need to be detached in order to remove the keyboard. The larger connector is the main keyboard cable.
  9. HP Elitebook 8460p Keyboard Replacement: adım 9, 2 resimden 1. HP Elitebook 8460p Keyboard Replacement: adım 9, 2 resimden 2.
    • Disconnect the keyboard cable on the laptop using a thin pry tool to open the connection.
    • Open the connection by inserting a thin plastic pry tool under the black tab in the connector and flipping it up.
  10. HP Elitebook 8460p Keyboard Replacement: adım 10, 2 resimden 1. HP Elitebook 8460p Keyboard Replacement: adım 10, 2 resimden 2.
    • Using the spudger again, disconnect the thin ribbon strip on the back of the keyboard.
    In step 5, there is an additional screw that is pictured near the exhaust fan that needs to be unscrewed before the keyboard is able to be removed in step 7.
    compuguy1088 - Yanıt
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
There's a third keyboard screw right beside the fan
Colin Chaplin - Yanıt
yeah just wanted to say this ...
Also the screws are PH1 not PH0
Robert Kohari -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 51
Her zaman: 4,161
