Ana içeriğe geç
HP Elitebook 8460p Modem Card Replacement
Neye ihtiyacın var
  1. HP Elitebook 8460p Modem Card Replacement, Battery: adım 1, 1 resimden 1.
    • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
  2. HP Elitebook 8460p Modem Card Replacement: adım 2, 1 resimden 1.
    • Slide the battery away from the switches until it can be lifted away from the laptop.
    • Lift the battery away from the laptop.
  3. HP Elitebook 8460p Modem Card Replacement, Back Panel: adım 3, 1 resimden 1.
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  4. HP Elitebook 8460p Modem Card Replacement: adım 4, 1 resimden 1.
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
  5. HP Elitebook 8460p Modem Card Replacement, Modem Card: adım 5, 2 resimden 1. HP Elitebook 8460p Modem Card Replacement, Modem Card: adım 5, 2 resimden 2.
    • Attach an ESD strap to your wrist and to a ground.
    • Using a Phillips #0 bit, remove the two 3.0 mm screws and set them off to the side side on a magnetic surface.
  6. HP Elitebook 8460p Modem Card Replacement: adım 6, 2 resimden 1. HP Elitebook 8460p Modem Card Replacement: adım 6, 2 resimden 2.
    • Push down on one corner of the sound card and lift it straight up.
  7. HP Elitebook 8460p Modem Card Replacement: adım 7, 2 resimden 1. HP Elitebook 8460p Modem Card Replacement: adım 7, 2 resimden 2.
    • Disconnect the wire plug by grasping the sound card in one hand and the wire in another and pulling them apart.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 36
Her zaman: 1,738
