Ana içeriğe geç
HP Elitebook 8460p Optical Drive Replacement
Neye ihtiyacın var
  1. HP Elitebook 8460p Optical Drive Replacement, Battery: adım 1, 1 resimden 1.
    • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
  2. HP Elitebook 8460p Optical Drive Replacement: adım 2, 1 resimden 1.
    • Slide the battery away from the switches until it can be lifted away from the laptop.
    • Lift the battery away from the laptop.
  3. HP Elitebook 8460p Optical Drive Replacement, Back Panel: adım 3, 1 resimden 1.
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  4. HP Elitebook 8460p Optical Drive Replacement: adım 4, 1 resimden 1.
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
  5. HP Elitebook 8460p Optical Drive Replacement, Optical Drive: adım 5, 3 resimden 1. HP Elitebook 8460p Optical Drive Replacement, Optical Drive: adım 5, 3 resimden 2. HP Elitebook 8460p Optical Drive Replacement, Optical Drive: adım 5, 3 resimden 3.
    • Using a Phillips #0 bit, unscrew the one Phillips head screw.
    • Using a T2 Torx screwdriver, remove the two 8.0mm Torx screws.
  6. HP Elitebook 8460p Optical Drive Replacement: adım 6, 2 resimden 1. HP Elitebook 8460p Optical Drive Replacement: adım 6, 2 resimden 2.
    • With your fingernail, pry the edge of the optical drive away from the chassis of the laptop and pull it straight out.
  7. HP Elitebook 8460p Optical Drive Replacement: adım 7, 3 resimden 1. HP Elitebook 8460p Optical Drive Replacement: adım 7, 3 resimden 2. HP Elitebook 8460p Optical Drive Replacement: adım 7, 3 resimden 3.
    • Skip this step if you are removing the optical drive to fix or replace a different component in the laptop.
    • Using a small paper clip, push the paper clip straight in to open the optical drive.
  8. HP Elitebook 8460p Optical Drive Replacement: adım 8, 3 resimden 1. HP Elitebook 8460p Optical Drive Replacement: adım 8, 3 resimden 2. HP Elitebook 8460p Optical Drive Replacement: adım 8, 3 resimden 3.
    • Using a small point, pop the tab out.
    • Rotate the plastic cover clockwise to release the tab on the left hand side of the optical drive.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Thanks for your help sir and I am really grateful
Mubarak Abubakar - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 18
Son 30 gün: 33
Her zaman: 1,173
