Ana içeriğe geç
HP Elitebook 8570w Optical Drive Replacement
Neye ihtiyacın var
  1. HP Elitebook 8570w Optical Drive Replacement, Optical Drive: adım 1, 1 resimden 1.
    • Begin by removing the computers back covering.
    • Use the right slider to unlock the backing.
    • Slide the backing towards you while holding the slider to remove it.
  2. HP Elitebook 8570w Optical Drive Replacement: adım 2, 1 resimden 1.
    • Once the backing is removed, locate the panel to the left where the optical drive is stored.
    • Locate the single screw in the photo.
    • Unscrew the 0.8mm Phillips screw and place to the side.
  3. HP Elitebook 8570w Optical Drive Replacement: adım 3, 1 resimden 1.
    • Locate the small metal piece in the photo.
    • Using a tool, push the piece in the given direction.
  4. HP Elitebook 8570w Optical Drive Replacement: adım 4, 2 resimden 1. HP Elitebook 8570w Optical Drive Replacement: adım 4, 2 resimden 2.
    • Once pushing the piece outwards, the optical drive will pop out of the side of the computer.
    • Grab the optical drive and carefully remove it from the back of the computer.
Sonuç
MJ Routh
465 İtibar
3 adet Kılavuz yazıldı
Ekip
Baylor, Team S8-G5, Johnson Fall 2017 Baylor, Team S8-G5, Johnson Fall 2017 üyesi
BU-JOHNSON-F17S8G5
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 16
Son 30 gün: 28
Her zaman: 1,945
