Ana içeriğe geç
HP Elitebook Folio 9470m WiFi Card Replacement
Neye ihtiyacın var
  1. HP Elitebook Folio 9470m WiFi Card Replacement, WiFi Card: adım 1, 2 resimden 1. HP Elitebook Folio 9470m WiFi Card Replacement, WiFi Card: adım 1, 2 resimden 2.
    • Flip the laptop over.
  2. HP Elitebook Folio 9470m WiFi Card Replacement: adım 2, 2 resimden 1. HP Elitebook Folio 9470m WiFi Card Replacement: adım 2, 2 resimden 2.
    • Remove battery using This guide.
  3. HP Elitebook Folio 9470m WiFi Card Replacement: adım 3, 3 resimden 1. HP Elitebook Folio 9470m WiFi Card Replacement: adım 3, 3 resimden 2. HP Elitebook Folio 9470m WiFi Card Replacement: adım 3, 3 resimden 3.
    • Using a Phillips screwdriver, carefully unscrew the two screws securing the hard drive plate. Once the screws are removed, gently lift and set aside the hard drive plate to access the components beneath it.
  4. HP Elitebook Folio 9470m WiFi Card Replacement: adım 4, 3 resimden 1. HP Elitebook Folio 9470m WiFi Card Replacement: adım 4, 3 resimden 2. HP Elitebook Folio 9470m WiFi Card Replacement: adım 4, 3 resimden 3.
    • Using a Phillips screwdriver, carefully remove the three screws securing the back plate. Once the screws are removed, gently lift the back plate slightly and slide it out to detach it from the laptop.
  5. HP Elitebook Folio 9470m WiFi Card Replacement: adım 5, 2 resimden 1. HP Elitebook Folio 9470m WiFi Card Replacement: adım 5, 2 resimden 2.
    • Slowly but firmly pull off the small connector on the right side.
  6. HP Elitebook Folio 9470m WiFi Card Replacement: adım 6, 3 resimden 1. HP Elitebook Folio 9470m WiFi Card Replacement: adım 6, 3 resimden 2. HP Elitebook Folio 9470m WiFi Card Replacement: adım 6, 3 resimden 3.
    • Unscrew the top Phillips screw and gently lift up and out to remove it.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Kenneth Bowers
1.432 İtibar
7 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G1, Valliere Fall 2018 UMass Dartmouth, Team S1-G1, Valliere Fall 2018 üyesi
UMASSD-VALLIERE-F18S1G1
4 Üyeler
19 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 46
Her zaman: 3,320
