Ana içeriğe geç
HP Elitebook x360 1030 G2 Battery Replacement
Neye ihtiyacın var
    • Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
    • Disconnect the power from the computer by unplugging the power cord from the computer.
    • Disconnect all external devices from the computer.
  1. HP Elitebook x360 1030 G2 Battery Replacement, Remove the bottom cover: adım 2, 2 resimden 1. HP Elitebook x360 1030 G2 Battery Replacement, Remove the bottom cover: adım 2, 2 resimden 2.
    • Remove the five Torx-4 T4M2.0×7.4 shoulder screws that secure the bottom cover to the computer.
    • Use a spudger to separate the rear edge of the bottom cover and the keyboard/top cover.
    • Remove the bottom cover by sliding it up and back at an angle.
  2. HP Elitebook x360 1030 G2 Battery Replacement, Remove the battery: adım 3, 1 resimden 1.
    • Disconnect the battery cable from the system board.
    • Remove the six Phillips PM2.0×5.3 screws that secure the battery to the keyboard/top cover.
    • Remove the battery.
Sonuç
To replace the battery & reassemble your device, follow these instructions in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
Max Kletskov
40.307 İtibar
16 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
136 Üyeler
17.430 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 44
Son 30 gün: 151
Her zaman: 4,077
