Ana içeriğe geç
HP Elitebook x360 1040 G5 Screen display Replacement
Neye ihtiyacın var
  1. HP Elitebook x360 1040 G5 Screen display Replacement, Screen display: adım 1, 3 resimden 1. HP Elitebook x360 1040 G5 Screen display Replacement, Screen display: adım 1, 3 resimden 2. HP Elitebook x360 1040 G5 Screen display Replacement, Screen display: adım 1, 3 resimden 3.
    • Open your laptop.
    • Apply heat to the perimeter of screen display using the low setting on the heat gun or hair dryer. Keep the heat gun at least 6 inches away from the device at all time to prevent damage to other components.
    • Continue to apply heat for 5 to 10 minutes.
  2. HP Elitebook x360 1040 G5 Screen display Replacement: adım 2, 3 resimden 1. HP Elitebook x360 1040 G5 Screen display Replacement: adım 2, 3 resimden 2. HP Elitebook x360 1040 G5 Screen display Replacement: adım 2, 3 resimden 3.
    • Using the jimmy tool pry outward on the screen display, starting near one of the top corners.
    • Carefully pry along the perimeter of the display until the screen can be easily removed.
    • Lay the screen face down on the keyboard for the next step.
  3. HP Elitebook x360 1040 G5 Screen display Replacement: adım 3, 2 resimden 1. HP Elitebook x360 1040 G5 Screen display Replacement: adım 3, 2 resimden 2.
    • Carefully remove the clear adhesive protector from the smallest ribbon cable, located closest to the laptop hinge.
    • Gently slide the connector out of the harness, moving it towards the side of the laptop with the power button.
  4. HP Elitebook x360 1040 G5 Screen display Replacement: adım 4, 3 resimden 1. HP Elitebook x360 1040 G5 Screen display Replacement: adım 4, 3 resimden 2. HP Elitebook x360 1040 G5 Screen display Replacement: adım 4, 3 resimden 3.
    • Carefully remove the clear adhesive protector from the last ribbon cable, located on the large black strip on the back of the screen display.
    • Gently remove the ribbon cable from the harness by moving it toward the laptop hinge.
  5. HP Elitebook x360 1040 G5 Screen display Replacement: adım 5, 3 resimden 1. HP Elitebook x360 1040 G5 Screen display Replacement: adım 5, 3 resimden 2. HP Elitebook x360 1040 G5 Screen display Replacement: adım 5, 3 resimden 3.
    • Remove the screen from the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Tyler A Cobb
321 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G1, Hovde Fall 2019 IUPUI, Team S1-G1, Hovde Fall 2019 üyesi
IUPUI-HOVDE-F19S1G1
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 44
Her zaman: 1,514
