Ana içeriğe geç
HP Elitebook x360 1040 G5 Speakers Replacement
Neye ihtiyacın var
  1. HP Elitebook x360 1040 G5 Speakers Replacement, Lower Case: adım 1, 2 resimden 1. HP Elitebook x360 1040 G5 Speakers Replacement, Lower Case: adım 1, 2 resimden 2.
    • Power off device before disassembly.
    • Use the T5 Torx screwdriver to remove the six 4 mm screws from the underside of the laptop.
  2. HP Elitebook x360 1040 G5 Speakers Replacement: adım 2, 2 resimden 1. HP Elitebook x360 1040 G5 Speakers Replacement: adım 2, 2 resimden 2.
    • Pry open the lower case from where it meets the laptop base.
    • Remove the lower case from the work area.
  3. HP Elitebook x360 1040 G5 Speakers Replacement, Battery: adım 3, 2 resimden 1. HP Elitebook x360 1040 G5 Speakers Replacement, Battery: adım 3, 2 resimden 2.
    • Use the Phillips 1 screwdriver to remove the five 3mm Phillips screws from the battery assembly.
  4. HP Elitebook x360 1040 G5 Speakers Replacement: adım 4, 3 resimden 1. HP Elitebook x360 1040 G5 Speakers Replacement: adım 4, 3 resimden 2. HP Elitebook x360 1040 G5 Speakers Replacement: adım 4, 3 resimden 3.
    • Carefully remove the power supply connector by pulling on both sides of its head.
    • Do not tug on the wires as they may become damaged.
    • Lift the battery from its position, removing it from the device.
  5. HP Elitebook x360 1040 G5 Speakers Replacement, Speakers: adım 5, 2 resimden 1. HP Elitebook x360 1040 G5 Speakers Replacement, Speakers: adım 5, 2 resimden 2.
    • Use the Phillips 0 screwdriver to remove the four 3mm Phillips screws from the speaker assembly.
  6. HP Elitebook x360 1040 G5 Speakers Replacement: adım 6, 3 resimden 1. HP Elitebook x360 1040 G5 Speakers Replacement: adım 6, 3 resimden 2. HP Elitebook x360 1040 G5 Speakers Replacement: adım 6, 3 resimden 3.
    • Carefully remove the plug, connecting the speaker assembly to the motherboard on the right hand side, by pulling on either side of its head.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Corey Agena
794 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G4, Maness Spring 2019 Cal Poly, Team S1-G4, Maness Spring 2019 üyesi
CPSU-MANESS-S19S1G4
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 498
