Ana içeriğe geç
HP Envy 15-u001dx Hard Drive Replacement
Neye ihtiyacın var
  1. HP Envy 15-u001dx Hard Drive Replacement, HP Envy 15-u001dx Disassembly: adım 1, 1 resimden 1.
    • Remove the two no-slip covers on the rear, bottom side using spudger shown in top center of picture.
    • The two in the front do not have to be removed as there are no screws underneath them.
  2. HP Envy 15-u001dx Hard Drive Replacement: adım 2, 1 resimden 1.
    • Remove the two cover tabs towards center of the bottom as there are screws underneath them.
  3. HP Envy 15-u001dx Hard Drive Replacement: adım 3, 1 resimden 1.
    • Remove all fourteen 4.5 mm screws from the bottom using a Phillips #0 screwdriver. Each location is marked by a red circle in the picture.
  4. HP Envy 15-u001dx Hard Drive Replacement: adım 4, 1 resimden 1.
    • Separate the top cover by using a spudger to go around the sides freeing the inside latches.
    • Once the bottom is free, carefully open to the inside as there are two ribbons that connect your keyboard and touch pad to the top cover.
  5. HP Envy 15-u001dx Hard Drive Replacement: adım 5, 2 resimden 1. HP Envy 15-u001dx Hard Drive Replacement: adım 5, 2 resimden 2.
    • Use the spudger to detach the two ribbons from their connectors.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
  6. HP Envy 15-u001dx Hard Drive Replacement, Hard Drive: adım 6, 1 resimden 1.
    • Gently remove hard drive from its connector.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Dakota Presley
885 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-4, Lacy Fall 2016 USF Tampa, Team 9-4, Lacy Fall 2016 üyesi
USFT-LACY-F16S9G4
4 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 15
Her zaman: 2,084
