Ana içeriğe geç
HP Envy 15-u001dx Motherboard Replacement
Neye ihtiyacın var
  1. HP Envy 15-u001dx Motherboard Replacement, Motherboard: adım 1, 3 resimden 1. HP Envy 15-u001dx Motherboard Replacement, Motherboard: adım 1, 3 resimden 2. HP Envy 15-u001dx Motherboard Replacement, Motherboard: adım 1, 3 resimden 3.
    • Flip the device over so the bottom is is facing up.
    • Peel up the two rubber feet closest to the hinge using the metal spudger to reveal two 6.6 mm Phillips #0 screws.
  2. HP Envy 15-u001dx Motherboard Replacement: adım 2, 2 resimden 1. HP Envy 15-u001dx Motherboard Replacement: adım 2, 2 resimden 2.
    • Peel up the small plastic coverings in the middle of the device with the spudger to reveal two more 6.6 mm Phillips #0 screws.
  3. HP Envy 15-u001dx Motherboard Replacement: adım 3, 2 resimden 1. HP Envy 15-u001dx Motherboard Replacement: adım 3, 2 resimden 2.
    • Remove each of the fourteen 6.6 mm Phillips #0 screws with the Philips #0 screwdriver.
  4. HP Envy 15-u001dx Motherboard Replacement: adım 4, 1 resimden 1.
    • Flip the device over and open it to reveal the keyboard.
    • Use the metal spudger to pry the chassis apart and reveal the inside of the device.
  5. HP Envy 15-u001dx Motherboard Replacement: adım 5, 3 resimden 1. HP Envy 15-u001dx Motherboard Replacement: adım 5, 3 resimden 2. HP Envy 15-u001dx Motherboard Replacement: adım 5, 3 resimden 3.
    • Disconnect the T/P cable by flipping up the black plastic piece on the connector and pulling the cable out of the connector.
  6. HP Envy 15-u001dx Motherboard Replacement: adım 6, 3 resimden 1. HP Envy 15-u001dx Motherboard Replacement: adım 6, 3 resimden 2. HP Envy 15-u001dx Motherboard Replacement: adım 6, 3 resimden 3.
    • Disconnect the keyboard cable by flipping up the black plastic piece on the connector and pulling the cable out of the connector.
  7. HP Envy 15-u001dx Motherboard Replacement: adım 7, 3 resimden 1. HP Envy 15-u001dx Motherboard Replacement: adım 7, 3 resimden 2. HP Envy 15-u001dx Motherboard Replacement: adım 7, 3 resimden 3.
    • Disconnect the battery cable by flipping up the black plastic piece on the connector and pulling the cable out of the connector.
  8. HP Envy 15-u001dx Motherboard Replacement: adım 8, 3 resimden 1. HP Envy 15-u001dx Motherboard Replacement: adım 8, 3 resimden 2. HP Envy 15-u001dx Motherboard Replacement: adım 8, 3 resimden 3.
    • Disconnect the AUX/USB cable by flipping up the black plastic piece on the connector and pulling the cable out of the connector.
  9. HP Envy 15-u001dx Motherboard Replacement: adım 9, 3 resimden 1. HP Envy 15-u001dx Motherboard Replacement: adım 9, 3 resimden 2. HP Envy 15-u001dx Motherboard Replacement: adım 9, 3 resimden 3.
    • Disconnect the cable by flipping up the black plastic piece on the connector and pulling the cable out of the connector.
  10. HP Envy 15-u001dx Motherboard Replacement: adım 10, 3 resimden 1. HP Envy 15-u001dx Motherboard Replacement: adım 10, 3 resimden 2. HP Envy 15-u001dx Motherboard Replacement: adım 10, 3 resimden 3.
  11. HP Envy 15-u001dx Motherboard Replacement: adım 11, 3 resimden 1. HP Envy 15-u001dx Motherboard Replacement: adım 11, 3 resimden 2. HP Envy 15-u001dx Motherboard Replacement: adım 11, 3 resimden 3.
  12. HP Envy 15-u001dx Motherboard Replacement: adım 12, 3 resimden 1. HP Envy 15-u001dx Motherboard Replacement: adım 12, 3 resimden 2. HP Envy 15-u001dx Motherboard Replacement: adım 12, 3 resimden 3.
    • Disconnect the cable by gently pulling it out. The spudger may be used to help loosen it.
  13. HP Envy 15-u001dx Motherboard Replacement: adım 13, 3 resimden 1. HP Envy 15-u001dx Motherboard Replacement: adım 13, 3 resimden 2. HP Envy 15-u001dx Motherboard Replacement: adım 13, 3 resimden 3.
    • Remove the three 4.0 mm Phillips #0 screws with the Phillips #0 screwdriver on the fan.
    • Remove the fan by pulling it out of the chassis.
    • The connector tends to get stuck and forceful pulling will break it. Use the spudger to loosen the connector on each side.
  14. HP Envy 15-u001dx Motherboard Replacement: adım 14, 3 resimden 1. HP Envy 15-u001dx Motherboard Replacement: adım 14, 3 resimden 2. HP Envy 15-u001dx Motherboard Replacement: adım 14, 3 resimden 3.
    • This connector may be hard to see because it is connected on the underside of the motherboard.
  15. HP Envy 15-u001dx Motherboard Replacement: adım 15, 1 resimden 1.
    • Remove each of the six 4.0 mm screws with the Philips #0 screwdriver.
  16. HP Envy 15-u001dx Motherboard Replacement: adım 16, 1 resimden 1.
    • Remove each of the three 4.0 mm screws around the fan with the Philips #0 screwdriver.
    • The fan will now be loose, and easy to lift out.
  17. HP Envy 15-u001dx Motherboard Replacement: adım 17, 2 resimden 1. HP Envy 15-u001dx Motherboard Replacement: adım 17, 2 resimden 2.
    • Gently pry the heat sink loose to release the motherboard.
  18. HP Envy 15-u001dx Motherboard Replacement: adım 18, 2 resimden 1. HP Envy 15-u001dx Motherboard Replacement: adım 18, 2 resimden 2.
    • Disconnect the wifi card from the motherboard and remove the motherboard from the rest of the device.
  19. HP Envy 15-u001dx Motherboard Replacement: adım 19, 1 resimden 1.
    • The disconnected motherboard should look like the indicated photo.
Sonuç
Nathan Browning
373 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G1, Henning Fall 2019 IUPUI, Team S1-G1, Henning Fall 2019 üyesi
IUPUI-HENNING-F19S1G1
3 Üyeler
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 560
