Ana içeriğe geç
HP Envy 15-u001dx Screen Replacement
Neye ihtiyacın var
    1. HP Envy 15-u001dx Screen Replacement, Screen: adım 1, 1 resimden 1.
      • Remove the two screw covers located in the bottom corners of the screen and the 2.5 mm Phillips #0 screws underneath them.
      • If these screws are not removed and you separate the bottom portion of the screen, you will not be able to refasten the screen to the back because the screw tab will break.
      FixBot'a Sor
      Yorum Ekle
    2. HP Envy 15-u001dx Screen Replacement: adım 2, 2 resimden 1. HP Envy 15-u001dx Screen Replacement: adım 2, 2 resimden 2.
      • Only after removing the two bottom corner screws in Step 1, separate the screen from the back using an opening tool.
      FixBot'a Sor
      Yorum Ekle
    3. HP Envy 15-u001dx Screen Replacement: adım 3, 1 resimden 1.
      • Remove the two 2.5 mm Phillips #0 screws with a Phillips#0 Screwdriver.
      FixBot'a Sor
      Yorum Ekle
    4. HP Envy 15-u001dx Screen Replacement: adım 4, 1 resimden 1.
      • Detach the webcam from the damaged screen using spudger.
      • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
      FixBot'a Sor
      Yorum Ekle
    5. HP Envy 15-u001dx Screen Replacement: adım 5, 1 resimden 1.
      • Gently detach small white connector with spudger.
      FixBot'a Sor
      Yorum Ekle
    6. HP Envy 15-u001dx Screen Replacement: adım 6, 1 resimden 1.
      • Gently remove the tape with the wire to completely separate the screen.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Joshua Madden
682 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 9-4, Lacy Fall 2016 USF Tampa, Team 9-4, Lacy Fall 2016 üyesi
USFT-LACY-F16S9G4
4 Üyeler
63 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 34
Her zaman: 2,119
