Ana içeriğe geç
HP Envy 17-3070NR Battery Replacement
Neye ihtiyacın var
  1. HP Envy 17-3070NR Battery Replacement, Back Cover: adım 1, 2 resimden 1. HP Envy 17-3070NR Battery Replacement, Back Cover: adım 1, 2 resimden 2.
    • Before you begin taking apart the computer, make sure that it is completely powered off.
    • Slide the release latch away from the nearest edge.
    • Slide the back cover off of the computer.
  2. HP Envy 17-3070NR Battery Replacement: adım 2, 3 resimden 1. HP Envy 17-3070NR Battery Replacement: adım 2, 3 resimden 2. HP Envy 17-3070NR Battery Replacement: adım 2, 3 resimden 3.
    • Remove the six 3.7mm Phillips screws.
    • Slide the back cover until it clicks, then lift it straight off.
  3. HP Envy 17-3070NR Battery Replacement, Battery: adım 3, 2 resimden 1. HP Envy 17-3070NR Battery Replacement, Battery: adım 3, 2 resimden 2.
    • Disconnect the multi-colored battery cable from the main assembly by gently pulling upward on it.
  4. HP Envy 17-3070NR Battery Replacement: adım 4, 3 resimden 1. HP Envy 17-3070NR Battery Replacement: adım 4, 3 resimden 2. HP Envy 17-3070NR Battery Replacement: adım 4, 3 resimden 3.
    • Remove the two 3.8 mm Torx screws using M8 Torx screwdriver.
    • Remove the battery by pulling it straight out away from the computer.
    • It is much easier to use the battery cable to carefully lift the battery off than to try to pry it off with tools.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Abby Lentz
586 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-8, Amido Spring 2015 Cal Poly, Team 14-8, Amido Spring 2015 üyesi
CPSU-AMIDO-S15S14G8
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 6
Son 30 gün: 10
Her zaman: 8,869
