Ana içeriğe geç
HP Envy 17-3070NR Hard Drive Replacement
Neye ihtiyacın var
  1. HP Envy 17-3070NR Hard Drive Replacement, Back Cover: adım 1, 2 resimden 1. HP Envy 17-3070NR Hard Drive Replacement, Back Cover: adım 1, 2 resimden 2.
    • Before you begin taking apart the computer, make sure that it is completely powered off.
    • Slide the release latch away from the nearest edge.
    • Slide the back cover off of the computer.
  2. HP Envy 17-3070NR Hard Drive Replacement: adım 2, 3 resimden 1. HP Envy 17-3070NR Hard Drive Replacement: adım 2, 3 resimden 2. HP Envy 17-3070NR Hard Drive Replacement: adım 2, 3 resimden 3.
    • Remove the six 3.7mm Phillips screws.
    • Slide the back cover until it clicks, then lift it straight off.
  3. HP Envy 17-3070NR Hard Drive Replacement, Hard Drive: adım 3, 3 resimden 1. HP Envy 17-3070NR Hard Drive Replacement, Hard Drive: adım 3, 3 resimden 2. HP Envy 17-3070NR Hard Drive Replacement, Hard Drive: adım 3, 3 resimden 3.
    • Remove the four 3.7mm Phillips screws that hold the hard drive onto the computer.
    • Remove the hard drive by lifting it out of its cavity.
    • Unplug the hard drive cable that connects it to the main assembly.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jasper Lewin
750 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-8, Amido Spring 2015 Cal Poly, Team 14-8, Amido Spring 2015 üyesi
CPSU-AMIDO-S15S14G8
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 20
Her zaman: 4,529
