Ana içeriğe geç
HP Envy 17-3070NR Optical Drive Replacement
Neye ihtiyacın var
  1. HP Envy 17-3070NR Optical Drive Replacement, Back Cover: adım 1, 2 resimden 1. HP Envy 17-3070NR Optical Drive Replacement, Back Cover: adım 1, 2 resimden 2.
    • Before you begin taking apart the computer, make sure that it is completely powered off.
    • Slide the release latch away from the nearest edge.
    • Slide the back cover off of the computer.
  2. HP Envy 17-3070NR Optical Drive Replacement: adım 2, 3 resimden 1. HP Envy 17-3070NR Optical Drive Replacement: adım 2, 3 resimden 2. HP Envy 17-3070NR Optical Drive Replacement: adım 2, 3 resimden 3.
    • Remove the six 3.7mm Phillips screws.
    • Slide the back cover until it clicks, then lift it straight off.
  3. HP Envy 17-3070NR Optical Drive Replacement, Optical Drive: adım 3, 3 resimden 1. HP Envy 17-3070NR Optical Drive Replacement, Optical Drive: adım 3, 3 resimden 2. HP Envy 17-3070NR Optical Drive Replacement, Optical Drive: adım 3, 3 resimden 3.
    • Remove the four 3.7mm Phillips screws that secure the optical drive to the computer.
    • Slowly lift the optical drive away from the computer ensuring that you don't put stress on the connecting cable.
    • Do not fully lift off the optical drive as there is still a cable that connects it to the motherboard.
    • Remove Sub Speaker assembly first in order to remove Optical drive. Carefully disconnect speaker connector.
  4. HP Envy 17-3070NR Optical Drive Replacement: adım 5, 3 resimden 1. HP Envy 17-3070NR Optical Drive Replacement: adım 5, 3 resimden 2. HP Envy 17-3070NR Optical Drive Replacement: adım 5, 3 resimden 3.
    • Carefully disconnect the connecting cable by lifting the white clamp with a Flathead screwdriver and pulling on the blue tab away from connector.
Sonuç
Jon Fuson
140 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 14-8, Amido Spring 2015 Cal Poly, Team 14-8, Amido Spring 2015 üyesi
CPSU-AMIDO-S15S14G8
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 1,244
