Ana içeriğe geç
HP Envy 17-3070NR RAM Replacement
Neye ihtiyacın var
  1. HP Envy 17-3070NR RAM Replacement, Back Cover: adım 1, 2 resimden 1. HP Envy 17-3070NR RAM Replacement, Back Cover: adım 1, 2 resimden 2.
    • Before you begin taking apart the computer, make sure that it is completely powered off.
    • Slide the release latch away from the nearest edge.
    • Slide the back cover off of the computer.
  2. HP Envy 17-3070NR RAM Replacement: adım 2, 3 resimden 1. HP Envy 17-3070NR RAM Replacement: adım 2, 3 resimden 2. HP Envy 17-3070NR RAM Replacement: adım 2, 3 resimden 3.
    • Remove the six 3.7mm Phillips screws.
    • Slide the back cover until it clicks, then lift it straight off.
  3. HP Envy 17-3070NR RAM Replacement, RAM: adım 3, 3 resimden 1. HP Envy 17-3070NR RAM Replacement, RAM: adım 3, 3 resimden 2. HP Envy 17-3070NR RAM Replacement, RAM: adım 3, 3 resimden 3.
    • Press down on both tabs on either side of the top RAM stick.
    • The RAM will slightly pop out and you will be able to slide it out of it's cavity.
    • Repeat the same process for the second stick of RAM if needed.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Abby Lentz
586 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-8, Amido Spring 2015 Cal Poly, Team 14-8, Amido Spring 2015 üyesi
CPSU-AMIDO-S15S14G8
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 787
